Pages: 1 [2] 3
Author Topic: Toe repairs  (Read 5548 times)
NathRobbo88
Re: Toe repairs
« Reply #15 on: January 23, 2012, 12:06:47 AM »
just carefull not to dent the bat when clamping- what do you guys do to ensure this doesn't happen?
Rather than using a clamp it may be better to cut an old grip into 1 inch pieces and stretch it over the toe.
Re: Toe repairs
« Reply #16 on: January 23, 2012, 12:08:05 AM »
Cut an old grip up, into pieces about 2-3 inches, and you can use that as a clamp.
It's been discussed on here about using that, I can't remember which site its on
kaustav
In Water I trust!!
Re: Toe repairs
« Reply #18 on: January 23, 2012, 12:11:24 AM »
Nathan you got to it first!
NathRobbo88
Re: Toe repairs
« Reply #19 on: January 23, 2012, 12:11:50 AM »
http://www.millichampandhall.co.uk/toe-repairs/toe-repairs.html
Have a look at this, it should help.
Re: Toe repairs
« Reply #20 on: January 23, 2012, 12:13:00 AM »
scottish_slogger95
Re: Toe repairs
« Reply #21 on: January 23, 2012, 12:17:26 AM »
cheers guys massive help. I take it I will not need a dowel then?
NathRobbo88
Re: Toe repairs
« Reply #22 on: January 23, 2012, 12:23:41 AM »
I'd put some in just to strengthen it. But thats me.
scottish_slogger95
Re: Toe repairs
« Reply #23 on: January 23, 2012, 12:24:29 AM »
I will take your advice seeing as I haven't done it before. Mind giving me a link to the dowel you use mate?
Re: Toe repairs
« Reply #24 on: January 23, 2012, 12:29:56 AM »
I'd be careful about putting dowel in, as it needs to be a snug fit, and using a normal drill may make a hole that isnt perfectly round so this may cause the dowel to not be snug. Unless you know of somewhere with a pillar drill that you can put a hole into the bat with, and then get a dowel in nice and tight!
scottish_slogger95
Re: Toe repairs
« Reply #25 on: January 23, 2012, 12:31:40 AM »
sounds a bit complicated and I don't have the materials so I think I will just follow the M&H method. Can I use that fevibond adhesive glue or does it have to be super glue?
Re: Toe repairs
« Reply #26 on: January 23, 2012, 12:33:45 AM »
When I repaired a bat of mine I used wood glue, if its a little thick water it down a bit, and make sure it gets right into the crack. I think you may be better off clamping that crack, as its a bit bigger than ones on the M&H site, but I'm not someone in the know about bat repairs really. It might be worth waiting a couple of days seeing if anyone who has repaired bats comments and gives you some advice on what to do mate :)
scottish_slogger95
Re: Toe repairs
« Reply #27 on: January 23, 2012, 12:35:24 AM »
Yeah I think it is best not to rush into this one as It could wreck the bat. What wood glue did you use wilkie mate?
kaustav
Re: Toe repairs
« Reply #28 on: January 23, 2012, 12:36:16 AM »
I agree with Tom. See if someone gives you more inputs; the dowel stuff would need precision.
In Water I trust!!
Re: Toe repairs
« Reply #29 on: January 23, 2012, 12:39:05 AM »
I just went to my local DIY store and got some wood glue mate.
I don't think it matters about a specific type mate :)
I repaired a few team mates bats, but nothing to the extent of what your's needs!
Putting the dowel in, would need a pillar drill I think, as like I said the other hand held drills you cant be precise with!
Pages: 1 [2] 3
