Author Topic: Should it stay, or should it go?  (Read 4277 times)
Mr Cricket
« on: January 25, 2012, 09:36:24 PM »
In two minds. Ordered a Redback towards the end of last season and it came heavier (2'15) than i had asked for (2'12).
I mentioned to Gary that it was not to spec. Being the reputable craftsman he is, he offered to take it back and alter it for me.
Then, last game of last season I absolutely smashed 100 with it having scored a steady 50 with it the week before.
Do I keep something that doesn't feel right for me? or return something that obviously works for me?
Sorry if this appears contradictory but that's why I'm asking!
Ironically, isn't this just the definition of the word 'Paradox'!
Re: Should it stay, or should it go?
« Reply #1 on: January 25, 2012, 09:42:54 PM »
Can't be too bad if u scored a tonne with it, must have used up full range of shots when scoring those runs so those extra 3oz can't be paramount to your overall performance.
Without a set of scales would you have known it was heavier?
thecord
« Reply #2 on: January 25, 2012, 09:44:52 PM »
If you can score a steady 50 and blast a 100 it seems that you are able to use for varying situations/styles of play too
Ryan
  • Trade Count: (+17)
« Reply #3 on: January 25, 2012, 09:47:26 PM »
Keep it, must be doing your game some good!
Mr Cricket
« Reply #4 on: January 25, 2012, 09:48:17 PM »
I would have noticed without the scales for sure. I'm worried about facing someone with true pace or someone who's jagging it around, I feel like I might be that split second later than usual due to the extra bit of weight. Maybe worth waiting until facing our own quicks at indoor nets on hard, bouncy surfaces to make my mind up.
« Reply #5 on: January 25, 2012, 10:01:11 PM »
If you're still not sure, send it to Gary to shave a bit off of it. Surely it's worth keeping anyway, seeing that you got a 100 with it? :)
« Reply #6 on: January 25, 2012, 10:02:50 PM »
Give her a thrash in winter nets and see how you cope with it!
It's worth at least trying it and finding out, and if not you can sell it on after that
Ryan
« Reply #7 on: January 25, 2012, 10:06:16 PM »
Have a go with the bowling machine if your clubs got one. You'll know for sure then
thedon
« Reply #8 on: January 25, 2012, 10:10:21 PM »
You order something that is supposed to be custom and it comes in 3oz heavier!
« Reply #9 on: January 25, 2012, 10:19:20 PM »
clearly a lovely bat, send it back to Gary and ask him to take some weight off.
that is the no loose position, or rather win win
« Reply #10 on: January 25, 2012, 10:20:50 PM »
Not every set of scales are calibrated the same as we have discussed before on several other threads so no point in goin over old ground
thedon
« Reply #11 on: January 25, 2012, 10:29:56 PM »
Redback being a retailer, his scales should be calibrated correctly.
Assuming his are, Mr Cricket you sure the bat is 3oz heavier? If Mr Cricket's scales are calibrated correctly, the first statement  is incorrect, and this, in my opinion is unacceptable
« Reply #12 on: January 25, 2012, 10:40:54 PM »
I have a set of scales in the office and one at home that give a 2oz diff between them....how do I know which set are correct?
RoCo Da Pixie
« Reply #13 on: January 25, 2012, 10:45:14 PM »
go for the inbetween weight.
thedon
« Reply #14 on: January 25, 2012, 10:53:09 PM »
     get 10,20,50,100G weights and calibrate them
