Author Topic: Sander  (Read 2151 times)
thedevil
Sander
« on: March 14, 2012, 07:52:37 AM »
Hi guys, just wanted to ask you all what type of sander is the best for sanding bats down, seen some which say sander/polisher but these are handheld, anyone know I these work or hot any good reccommendations id appreciate
Thanks
Simmy
Re: Sander
« Reply #1 on: March 14, 2012, 08:17:23 AM »
you need a big drum sander mate idearly or a sanding drum to go on a motor/polisher
on a drum sander the pad behind the sand paper os foam so u can push it hard to the bat
thedevil
Re: Sander
« Reply #2 on: March 14, 2012, 01:10:56 PM »
Cheers fletch, I've seen examples of the motor with the sanding drum/polisher  attached, and it looks good. Was hoping someone would be able to point me in the right direction for a motor which is ideal ?
Re: Sander
« Reply #3 on: March 14, 2012, 01:24:41 PM »
Best thing is to check on ebay. quite a few on there. im guessing you probably looking for 240v or single phase ( 2 names for household supply)
you want to keep the rpm relatively low. too high and you will remove too much wood too quickly or the work piece will burn/scorch. mines 1425 rpm.
RossViper
  • What noise does a cow make?
    • My Excel Blog!
Re: Sander
« Reply #4 on: March 14, 2012, 10:21:30 PM »
really, i've never been able to find one on ebay.... I thought they where quite rear..
Re: Sander
« Reply #5 on: March 14, 2012, 10:35:04 PM »
There are a few motors on there but none with the chucks already fitted. That's the hard bit
thedevil
Re: Sander
« Reply #6 on: April 02, 2012, 08:03:52 PM »
I've seen quite a few motors, but never know if the motor is ideal for what I want. Is there any specific type ?
