Author Topic: Reapplying twine on handle  (Read 1923 times)
mattw
    • PRYZM Cricket
« on: April 25, 2012, 06:58:51 PM »
Im refurbing a bat for my club and I've had a look at the twine and its started to come away from the handle at the bottom. What's the best/easiest way to reapply it?
Re: Reapplying twine on handle
« Reply #1 on: April 25, 2012, 07:10:59 PM »
Unwrap a bit more, glue the handle and then re apply and Use the tuck under/ pull through technique using a small section of binding in a loop to secure under the binding. Put the loop on the handle with the loop at the bottom. Wrap the binding around a handful of times. Put the loose end through the loop. Hold in place and pull the loop upwards towards the top of the handle. Should pull the loose bit/ end through and tuck it nearly underneath the binding. Trim and glue. Job done.
mattw
    • PRYZM Cricket
« Reply #2 on: April 25, 2012, 07:19:53 PM »
What glue would be the best to use? A wood glue?
« Reply #3 on: April 25, 2012, 07:33:59 PM »
I use pva but guess you could use wood glue.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #4 on: July 11, 2012, 10:29:09 AM »
pva IS wood glue
Fezballoh
« Reply #5 on: July 12, 2012, 05:58:35 AM »
Wood glue is waterproof PVA
