Pages: 1 2 [3]
Author Topic: You have access to all bat innovations and nothing is outlawed. What do you do?  (Read 11714 times)
Bez013
Would that work? as cross laminated sheets of Kevlar, Carbon Fibre and Glass Fibre will give a stiffness and strength but what about spring? Having had a few chats about making a bat like this with Malik was told it simply wouldn't work and they make some of the best sticks in the world.
Having messed around at the end of hockey sessions for many years a 36.5" 565g (about 1lb 2oz) stick goes like the clappers if you 'middle' one whilst playing cricket, I've cleared the fence at one end of the pitch from standing on the goal line at the other end of the pitch before but it isn't easy, that is probably a 1 in every 250 hit at over 90 metres but you can consistently hit over 3 quarters of the length of the pitch which would be nearly 70 metres from a very slow delivery.
Quite a few of the sticks have hollow tubes inside, I'd imagine a carbon bat to just be a bigger version of this - http://www.grays-hockey.co.uk/technology.asp see the GX Turbo Torque cross section about 2/3rs down the page,
As you say I'm not sure it would work scaled up but I'd still like to offer my services to try one to prove it doesn't work  :)
i'd put on an anti scuff sheet which was made of a special rubber and glue which turned my bat into a skyer like thing
Canners
  • go hard or go home
I will have a laminate low density willow harrow size Hades with a C6 handle. ;) :D
sounds tasty
whens it due?
ajm90
Bat hollowed and filled with the stuff they use to make the super bouncy balls.
Blazer
  • Team Anti - Concave !.
sounds tasty
whens it due?
It's fictional mate ;)
junter97
It has to be a laminate imo with a carbo handle and a 1.5inch shorter blade. Made out of a 'proper' low density cleft, preferably one of those oversized clefts and a lamitoe to finish it off
Number4
Pretty sure I said this on page 1... Get your own ideas ...haha  ;)
toby176
-Performance laminate
-Extra dry
-Carbon fibre back (like on kooks)
-Like 5 of this invention I saw on tv once. (found here http://www.abc.net.au/tv/newinventors/txt/s2523975.htm)
ammo
Laminated
 face= normal lush willow
Rest if the bat: Extra dry willow might get something with 50mm edges weighing 2.7
Mr Cricket
A willow-titanium laminate.
not illegal, but a very think handle so need need for two grips.
ajm90
sorry I didnt click on the first page.
Pages: 1 2 [3]
