Pages: [1] 2 3
Author Topic: Canes in pads  (Read 7675 times)
Canes in pads
« on: April 26, 2012, 12:44:23 PM »
since the start of pad making it appears that most pads have had cane to act as support or protection.
what other options are there? could you use plastic or something like that?
I appreciate that there are the aero or. Morrant offerings but I think more could be done on this area.
had anyone done any homework on this?
Talisman
  • Trade Count: (+76)
Re: Canes in pads
« Reply #1 on: April 26, 2012, 12:47:56 PM »
Sealed Air.
Joe
Re: Canes in pads
« Reply #2 on: April 26, 2012, 12:48:51 PM »
A.C.I.S Pads maybe?
Vic Nicholas
Re: Canes in pads
« Reply #3 on: April 27, 2012, 03:17:21 AM »
Sealed Air.
This is actually a great idea.
A variation of bubble wrap, but bigger cells. Put them inside a tradional looking pad facade and they would be the lightest pads around!!
That is a great concept...
straightdrive1
Re: Canes in pads
« Reply #4 on: April 27, 2012, 04:32:33 AM »
But what if the ball strikes the pads really hard & the bubble wrap pops?
Canners
  • go hard or go home
Re: Canes in pads
« Reply #5 on: April 27, 2012, 05:54:50 AM »
Reebok pump pads?
thinking about it isnt ACIS the same principle as the reebok pump?
Re: Canes in pads
« Reply #6 on: April 27, 2012, 06:23:34 AM »
Wouldn't it also have a bit of a trampoline effect on the ball.
Joe
Re: Canes in pads
« Reply #7 on: April 27, 2012, 06:25:47 AM »
Thin layer of HD foam in front of it maybe?
Canners
Re: Canes in pads
« Reply #8 on: April 27, 2012, 06:40:46 AM »
more value for your leg byes?
neilcounter
Re: Canes in pads
« Reply #9 on: April 27, 2012, 06:51:03 AM »
D3O perhaps???
In fact I thing Gunn and Moore now use this technology in some of their pads.
Re: Canes in pads
« Reply #10 on: April 27, 2012, 06:52:12 AM »
I have done some research into it previously by looking at using carbon fibre or fibreglass apex shaped canes to lighten the pads and give the structural strength still.
Air in another option we have looked at using but would require some RND investment to get samples up and running.
The "canes" in a set of pads I cut open were a piece of folded cardboard to form the apex and some garden cane cut to the same shape so not very technologically advanced considering the model of pad and price tag!
Everyone seems to band aboUt d3o on here but probably haven't seen it in sheet format to realise just how heavy it is let alone the expense of it.
« Last Edit: April 27, 2012, 06:54:39 AM by Ayrtek »
Re: Canes in pads
« Reply #11 on: April 27, 2012, 07:30:45 AM »
With the Air in the pads - I would see that as smaller versions of the "clappers" you get at sporting events - the issue would be getting them housed in an appropriate material and how to counter the loss of air over time (like tyres) would you have some form of pump?
The other option might be some form of "gel" filling for the tube rather than air - similar to what is used in shoes perhaps?
cardboard in pads - humm good job you didn't put them in the bath ;) !!
« Last Edit: April 27, 2012, 07:33:20 AM by Buzz »
Re: Canes in pads
« Reply #12 on: April 27, 2012, 07:33:25 AM »
We looked a valves you would blow up via your mouth as this would be the easiest option to house and would be simple to inflate if they needed it. Similar to what's on a beachball etc :)
Would be a big ole pump otherwise or take a lot of pumping to fill them
Ryan
  • Trade Count: (+17)
Re: Canes in pads
« Reply #13 on: April 27, 2012, 07:33:30 AM »
LIKE haha  :D
The_Bird
Re: Canes in pads
« Reply #14 on: April 27, 2012, 07:47:36 AM »
Bubble wrap is my weakness, I can see them being a brilliant stress release when you get out but then you'd be left with a couple of flat pads....haha
Pages: [1] 2 3
