Author Topic: Refurb Question  (Read 1760 times)
ca_gold
Refurb Question
« on: April 26, 2012, 05:56:19 PM »
Hi guys,
I did go through a whole host of topics in this section before posting but still wasnt clear what i should do. I'm in the process of refurbing one of my bats. I started by using the hair dryer method to remove the anti scruff sheet - it worked like a charm. The face of the bat still has a lot of sticky residue left from the scruff sheet. I tried sanding it but it is still there. Question:
1) How do i get rid of this sticky residue - more sanding? leave it for a few days to dry? should i just slap on a new sheet and not worry about the residue?
2) Should i oil the whole bat before sticking on a new sheet, or just stick on a new sheet and oil the back and sides?
thanks for the help
Re: Refurb Question
« Reply #1 on: April 26, 2012, 06:33:29 PM »
white spirit will get rid of the glue, then you can oil or not before you apply the new scuff sheet.
personally, I think it depends on how dry the bat is.
Re: Refurb Question
« Reply #2 on: April 26, 2012, 06:48:44 PM »
you can also use a stanley blade to scrape off the glue before sanding. may be worth a little coat of oil before the antiscuff as you are sanding it down but as buzz said see how dry it is
ca_gold
Re: Refurb Question
« Reply #3 on: April 26, 2012, 07:14:57 PM »
i think its pretty dry - my mate left it in a garage all winter.
thanks for the replies.
Re: Refurb Question
« Reply #4 on: April 26, 2012, 10:28:35 PM »
Unless the garage has central heating, most garages are relatively damp.
ca_gold
Re: Refurb Question
« Reply #5 on: April 26, 2012, 10:56:38 PM »
you may be right - it doesnt look to dry to me, even though the garage probably was -10 all winter (i'm in canada). i did net with it yesterday and it played brilliantly.
