Batting across the line.....
Author Topic: Batting across the line.....  (Read 3175 times)
BobbySheldon
  • The Swedish Jester
« on: July 22, 2012, 10:30:08 PM »
Hi guys,
I've dropped into a bad habit of playing across the line of the ball when I relax at the crease. I play myself in ok, then when I relax to play a few more attacking shots it goes to pot.
Does anyone know of a few drills I could do to help prevent this? I've lost three soft wickets to this so far this season.
Thanks
Scott
Watch the seam.......
Re: Batting across the line.....
« Reply #1 on: July 23, 2012, 02:54:00 AM »
Maybe you could try batting with just your top hand to some throw downs? I do this during net sessions when I feel my feet are either not moving enough or where I start to play across the line. Great thing about this drill is it helps strengthen your top hand, generally improves your driving technique, foot movement and makes you watch the ball very carefully.
Perhaps you could try opening your stance a little, or maybe even start off a few inches away from your guard and shuffle into it for a trigger movement. Not really tried these methods, so these are merely things to try if the above doesn't work. Of course, I would never try to bat one handed in a game!
Mr Cricket
« Reply #2 on: July 23, 2012, 07:13:00 PM »
just to echo the above really: loosen the grip with your bottom hand, try holding it in the fingers or go for the adam gilchrist squashball-in-the-palm technique, does wonders for your 'figure of 9'
MD2812
  • Hi, I'm Joe
« Reply #3 on: July 23, 2012, 07:45:58 PM »
Squash ball in the glove, is that a permanent or just temporary to get used to using less bottom hand?
« Reply #4 on: July 23, 2012, 08:01:14 PM »
i think you have found your problem, you are "relaxing" and losing your concentration.
You should be concentrating on every ball like it is your first and possibly your last delivery, even in the nets.
Nothing to do with technique just poor concentration and application, its the reason those cricketers that those average batsmen always seem to consistenyl score runs. Anyone can play a drive or square cut, the hard part is concentrating and appliying your skills properly. batting is fairly simple when you break down into its small component parts.
If it is straight, play straight, if it is on the offside paly it on the offside, if it is leg side play it on the leg side. Defend the good balls, attack the average balls and punish the bad balls.
« Reply #5 on: July 23, 2012, 08:02:50 PM »
(Initial Alignment to the ball)
The back swing is your first point of alignment and you need to get this right to be able to play the straight-batted shots well. The top of the back swing needs to be high over off-stump so that gravity can assist the top hand on the down swing towards the ball, this minimises bottom hand intervention.
At the top of the back swing your forearm should be bent at about 90 degrees pointing towards the bowler with the back arm in alignment. This will make your top hand dominant. It will also help you enhance your finish position with a high leading elbow on completion of the shot. It is important that the bottom hand is holding the bat only with fingers and thumb to ensure the top hand takes control. Short back lifts encourage too much bottom hand and I would advise you against having one.
Batters need to try to pick the bat up towards off-stump so that your bat can get good access to the ball on straight and especially leg-stump line deliveries. From this position the bat can swing in a straight line towards the ball with a full face.
After your initial back swing over off stump your shoulders should turn towards the line of the ball. As the shoulders turn the bat will move in line with them. So when the ball pitches outside off stump the bat position on the back swing will now be pointing towards leg stump and lined up perfectly to swing in a straight line towards the off side. If you do the above this will minimise the chances of playing across the line and getting out bowled or LBW.
Common Faults
• Leading shoulder side ways therefore the head is positioned to the off side and lures you in to tipping over. This can result in players getting squared up as they over compensate and get to open.
• Picking the bat up over leg stump means batter is set to play into the off side only. This lures him to tip to the off side and leaves a gap between bat and pad. This means you are vulnerable to being bowled or lbw.
• Bottom hand too tight with palm holding the handle of the bat too tightly. This can mean that the bat face closes to quickly when contacting the ball thus shortening your hitting zone.
• Back arm is tucked in and fore arms are not in line, this means the bat will not swing in a straight line towards the ball and batter will get squared up.
(Balance)
If your initial stance is correct with your feet level you will be in a good position to lean towards the ball. The thing to check is the position of your head and alignment of your shoulders. The head must be slightly forward of your body and above the front foot and in line with your toes. If your head is further across than your toes the chances are that you will tip to the off side and this will make it difficult for you to play straight.
Your eyes need to be level and your shoulders need to be in line with each other and also in line with the stumps at the other end of the pitch. A common problem is that the leading shoulder gets too closed or to far round and therefore the batter can’t help but fall to the off side. It’s more important to get the head pointing up the wicket rather than the shoulders. If the head is in position and the chin is close to the inside of the leading shoulder, then you are in a great position and well aligned, ready to lean in to the shot.
The problem of tipping to the offside is that players look only at the off side as their scoring area. Therefore they generally hit across the line when the ball is straight or on the leg stump. This means that the batter is presenting half a bat to the ball on contact and therefore risking missing it or getting a leading edge.
Hot Tip
Improving your on drives via opening the shoulders slightly with your front foot pointing up the wicket, positioned down the line of leg stump (no wider) with your back foot turning in towards the ball coupled with practising against feeds around the wicket will minimise tipping to the off side. When you can play the on drive well with around the wicket feeds, then progress to one over followed by one around alternatively. These alternate angles of feed will help fuse your balance into a more central position with your head in a neutral position ready to play off, on and straight drives with minimal risk of tipping over.
Common Faults
• Plying straight balls towards the off side.
• Playing around the front pad getting LBW, Bowled or caught from a leading edge.
• Not knowing what balls to leave and what to play outside off stump.
• Not being able to play in the V and therefore scoring options are square of the wicket on off and leg side.
(Positioning of feet) Forward:
When stepping forward make sure your front foot points towards the area you should be hitting the ball. If you put your front foot too sideways you will tip to the off side and will play around your front pad and hit across the line when the ball pitches on middle and leg line. This means you will find it difficult to swing the bat in a straight line towards the area you should be aiming the ball - straight and mid on. You will more often than not play the ball square of the wicket on the leg side (Square leg area). It is very difficult to play the ball through straight and mid on areas if the front foot lands too sideway.
Your front knee needs to be able to bend towards the line of the ball, again this is difficult if the foot lands too side ways. When driving through mid on and playing the front foot flick off the legs it is important to take a slightly smaller stride, point your font foot straighter up the wicket, turn your back foot inward slightly and make sure the foot lands down the line of leg stump and no wider.
The back foot should always have the heel raised off the ground when playing forward so that you really lean in to the shot and therefore have a large hitting area. This will make it easier to drive more deliveries along the ground. The head should always be forward of the front foot and perpendicularly in line with the body when stepping forward to ensure balance during the stroke.
Common Faults – Front foot
• Heel of back foot stays stuck to the floor thus limiting the batter's reach and hitting area.
• Front foot planted too sideways on leg stump line, encouraging hitting across the line.
• Front foot landing outside the line of leg stump to play an on drive this causes tipping to the off side and also playing across the line of the ball too much.
• Front foot lands pointing too straight on and outside off stump this causes lack of balance, tipping to the off side and also slicing the ball.
• Front foot planting across the line of the ball because of initial movement to the off side with a small stride, thus encouraging the player to play across the ball and around the front pad. Players that get out LBW do this a lot.
(Positioning of feet) Back:
When stepping back you need to get a good stride back and must always go across.
Never step straight back without going across at the same time.
The deeper you step the easier it is to keep you head forward of your body. Try to leave your head forward as you transfer your weight on to the back foot. The weight need to be on the back foot with the head over the front foot.
When the ball pitches on or outside off stump line the back foot should land parallel to the crease. When the ball pitches on middle and leg stump line the back foot turns in slightly and the front leg opens out so that you can swing the bat towards the ball in a straight line.
Common faults- Backfoot.
• The back foot is pointing down the wicket when the ball is on or outside off stump, this causes the bat to swing down the wrong line and can result in being caught behind.
• The back foot is too sideways on middle and leg stump line, this causes the batter to be too sideways and therefore closed off, thus finding is difficult to play the short ball.
• Front shoulder turns too much towards extra cover so the batter plays the ball too square of the wicket and therefore the batter is playing with half a bat with the arms away from the body.
(Stable base)
When playing, the front foot drives you must look to make contact with the ball forward of the front foot, this will lengthen your hitting zone. To do this you must lean towards the ball with the head forward of the body allowing the back heel to get off the ground thus allowing you to reach further forward and hit with a dominant top hand and fingers and thumb relaxed bottom hand. Making contact in font of the front foot will help you get more momentum in to the shot while hitting from a firm base. Try to stroke the ball in to the correct areas with good technique, don’t try to swing the bat too fast. Although you are trying to make contact with the ball in front of the front foot when driving, you still need to let the ball come to you rather than go at it too early. If your heel is still on the ground when playing forward, this means you are not leaning in enough.
Common Faults
• Too much bottom hand
• On point of contact palm of bottom hand is firmly touching the ground.
• Heel of back foot is still touching the floor
• Head is not Forward of the front foot.
• Head is not inline with the path of the bat towards the ball.
• Trying to swing the bat too fast. (Compromises efficient technique)
(Enhanced hitting area through the line of the ball)
If the back swing and the finished position are correct and you lean in to the shot the other areas should automatically fall in to place. The start and finish position of any shot are the most important areas to work on when coaching.
The finished position of any straight batted shot including the flick off the legs and leg glance must finish with a high leading elbow position. This is something that great players such as Sir Vivian Richards did exceptionally well. The diamond shape created in the back swing should be maintained throughout the shot and should be maintained in the finished position to allow you to play straight effectively.
When playing the drives, the check drive is the most efficient and successful way of playing the shot. The check drive will secure a large hitting zone and will ensure a full face of the bat through the line of the ball for an extended period of time thus allowing you to play straight more effectively. Doing this will minimise your chances of getting out to the ball that moves in the air or off the wicket. It will also make improvised shot play more effective when playing in a wide V both along the ground or in the air. When practising try to exaggerate these finished positions and hold the shapes of the shot for a few seconds so that they get imbedded in the muscle memory and are therefore easy to recreate in matches.
Hot Tip
T ry to look through the bottom forearm on completion of all font and back foot drives, finish the shot with high hands above the line of your head. To do this well you bottom hand will need to be relaxed and your top hand in charge of the shot.
Common Faults
• Collapsing the leading elbow too early in the shot.
• Bottom hand too tight, therefore restricting the flow of the arms and bat through the shot.
• Players implementing the full swing and swinging the bat over their shoulder thus shortening the hitting zone and closing the bat face to early in the shot.
The best players in the world the implement the above correct techniques and are very efficient in playing with a straight bat. Great players have a good basic technique but have the ability to attach their natural flare to their correct technical base when they need to improvise. They know how fare they can push the boundaries of that technique through trial and error in match situations. When great players play on a bad pitches or come up against an exceptional spell of bowling they have a good technique to fall back on to survive and succeed.
Conclusion
There is no substitute for correct efficient technique, when learning the various shots the straight batted ones need to be perfected first. These shots are a must to succeed at a higher level. Playing straight will improve your consistency and will build your confidence. When the confidence is high you will take on the challenging run chase situations in a more positive frame of mind and will be successful in more situations.
« Reply #6 on: July 23, 2012, 08:04:09 PM »
i'd say check your drives to and go 70% power, a 6 is only two more than a 4 and probably 75% more chance of being dismissed.
Is it worth it for 2 extra runs?
Mr Cricket
« Reply #7 on: July 23, 2012, 08:22:06 PM »
BobbySheldon
« Reply #8 on: July 24, 2012, 01:10:09 PM »
Thanks for the advice guys,
This little lot will give some homework for the next week or so. I'll let you know how it goes.
BobbySheldon
« Reply #9 on: July 31, 2012, 10:13:10 AM »
Opening my stance and slightly relaxing the grip of my bottom hand seems to be doing the trick guys. Lets hope I hit a 20+ in the next game.
« Reply #10 on: July 31, 2012, 10:16:20 AM »
sounds promoising, keep playing straight and keep concentrating every ball
dont get frustrated if it isnt going to plan  ..... thats the hardest part of batting
