Author Topic: GM RSB Original Pads  (Read 3708 times)
BakarooBonzai
« on: August 13, 2012, 06:28:55 AM »
I've been using these pads the second half of the season and they are still quite stiff and doesn't really have that "wrap around" feeling or look.  Just wondering if anyone else has these and did they get any better.  Is there anything else I can do other than wearing them and breaking them in for a longer period?
junter97
Re: GM RSB Original Pads
« Reply #1 on: August 13, 2012, 09:08:26 AM »
Do you just throw them in your bag afterwards?
hammersjr
« Reply #2 on: August 13, 2012, 12:18:45 PM »
Do you like these pads? Would you recomend them?
BakarooBonzai
« Reply #3 on: August 13, 2012, 08:47:43 PM »
@junter97: I air them out overnight and then in my kit bag till next game.  Does that make a difference?
I like them but they are a bit stiff, but the weight and protection is top notch.  Straps are of good quality and the pads don't shift during running.  Inner padding is movable and anatomically shaped so the knee rests comfortably.  Finish and stitching seems pretty good, but only time will tell how well they fair.
junter97
« Reply #4 on: August 13, 2012, 08:59:29 PM »
So you don't strap them up again before they go in the bag? I do this and I find it makes them wrap around your leg more, you have to tighten them quite a bit though.
Watsontotty
« Reply #5 on: August 13, 2012, 09:12:51 PM »
I'm a fan of 2 strap pads and plan to move back to them once i find something in a sale at the end of the season, i haven't tried the the GM version but im seriously considering them as my next batting pad.
Dan W
« Reply #6 on: August 13, 2012, 09:13:34 PM »
This, as standard with all new pads!
BakarooBonzai
« Reply #7 on: August 13, 2012, 10:58:50 PM »
Yeah I haven't been strapping them tight when I put them in the kit bag.  I'll give it a try, thanks.
@Watsontotty: I have also contemplated the two/three strap pads.  I sometimes find that the three strap type to be a little uncomfortable at the calf area.  I've never worn top of the line three strap type, perhaps they are more comfortable.  I like these pads quite a bit, they feel awesome during matches, never had to readjust during play.  This is my first foray into molded pads, and I like them so far.  I really wanted a pair of morrantz but they were a bit pricey for me but overall happy with the GM's.
« Reply #8 on: August 14, 2012, 07:25:50 AM »
Having a set of GM three straps and the Puma two straps, I'd have to say that I do like only two straps a lot more than I thought. No strap rubbing behind the knee and they stay on just fine!
hammersjr
« Reply #9 on: August 15, 2012, 01:17:08 PM »
Which Puma's you got, I've got the Puma Iridium 6000's which are two strap and I find them much more comfortable.
SaadIjaz
« Reply #10 on: August 23, 2012, 10:49:18 PM »
Anyone looking for the RSB GM pads - came across a bargain here at prodirect
www.prodirectcricket.com/Products/Gunn-Moore-RSB-Original-5-Star-Batting-Pads-Batting-Equipment-WhiteBlackSilver-40860.aspx
Although I really don't Understand why Ravi Bopara goth pair of pads designed and named after him :o he's not that good!
« Last Edit: August 23, 2012, 10:52:15 PM by SaadIjaz »
The superior man is modest in his speech, but exceeds in his actions.
