Author Topic: Gray-Nicolls Titanium bats from 2010.  (Read 4451 times)
RightArmRapid
« on: August 14, 2012, 11:59:35 AM »
Out of curiosity does anybody here know what  willow grade the Powerbow Titanium bat from 2010 was? Thank you in advance.
Joe
Re: Gray-Nicolls Titanium bats from 2010.
« Reply #1 on: August 14, 2012, 05:05:40 PM »
probably covered/fake grains - the gn models with words describing them are usually so
RightArmRapid
« Reply #2 on: August 14, 2012, 05:23:37 PM »
In the description for GN bats of old it says the bat had titanium in the handle much like "carbo" bat's used carbon fibre in the handle but it didn't mention the grade. It doesn't look covered and the grains most certainly aren't fake however the grain structure isn't even close to grade 1 quality, 8 wavy grains. However the Owzat article regarding willow grading is contrary to this.
Grade 1 plus - G1+.... the very best of English willow, often reserved for the manufacturers own Pro Players and utilised in such bats described as Limited Edition, Ultimate, SPS or Pro-Performance. Unbleached with straight even grains and absolute minimal marking or discolouration in the face.
Grade 1 - G1 .... top quality English Willow, used in such bats described as Pro, Original, Titanium, Premier or Players. Good straight grain structure and unbleached with minimal marking or discolouration in the face.
Grade 2 - G2 ... Unbleached English Willow with some irregular grain patterning and some minor blemishes and possible reddening in the blade.
Grade 3 - G3 ..... Usually unbleached English Willow with irregular grain pattern and some marking and discolouration in the blade.
Grade 4 - G4 ... English Willow usually bleached and often non oil with a covering to the face of the bat.
http://www.owzat-cricket.co.uk/about_cricket_bats/about_cricket_bats.htm
Don't know how to post images yet, but I can link the Photobucket pictures if required.
Thanks for the swift response,
Peter.
Liam-SCCC
« Reply #3 on: August 14, 2012, 06:19:40 PM »
I'm pretty sure the titaniums were top grade, will see if I can dig out some old catalogs
Top Score: 102*
Best Bowling: 7/29
RightArmRapid
« Reply #4 on: August 14, 2012, 06:28:20 PM »
Thank's that would be much appreciated Liam, like I said I could link the photos of it from photobucket if needed, and it's just a matter of curiosity the bat is an absolute belter either way ;)
RightArmRapid
« Reply #5 on: August 14, 2012, 06:45:17 PM »
Hope this works!
toenails97
« Reply #6 on: August 14, 2012, 06:52:37 PM »
Nice bat,,, I'd say grade 2
RightArmRapid
« Reply #7 on: August 14, 2012, 07:11:24 PM »
I myself have only used it in about 3 matches but it mostly ends up being used in matches and nets by team mates which love it, it weighs about 2.10 but I much prefer my match bat just wanted to know as I've been asked on numerous occasions what grade It's actually supposed to be! Thanks for all of the responses, it's much appreciated:)
Watsontotty
« Reply #8 on: August 14, 2012, 08:18:36 PM »
from memory im pretty sure they were G1 willow
RightArmRapid
« Reply #9 on: August 14, 2012, 09:18:22 PM »
I thought so, It's just that the bat doesn't really look g1.
Watsontotty
« Reply #10 on: August 14, 2012, 09:24:19 PM »
a number of higher range bats don't look the part and a number of lower grades look a million dollars so i don't work off looks alone. Think there was a GM 909 on here which had 18 grains or something like that and could have been put up as an orginal Le as it looked that good and i had a top end Ricky Ponting Kahuna which had 8 grains and looked nothing special in regards to looks.
