Author Topic: adhesive on the bat face  (Read 2361 times)
joeylough
  • One hit wonder
« on: August 16, 2012, 06:04:23 PM »
Hello, ive took some fibre tape of my bat and there is adhesive left on the bat. What is the best way to get rid of this?
@joey_lough
Vantage_Cricket
Re: adhesive on the bat face
« Reply #1 on: August 16, 2012, 06:07:42 PM »
Always annoying! I try and get an old credit card or something you can scrape it off with and then maybe a bit of white spirit try remove the stickyness of it.
« Reply #2 on: August 16, 2012, 06:25:12 PM »
i use beeswax
Offthesquare
« Reply #3 on: August 16, 2012, 06:29:20 PM »
Very sharpe knife blade - Stanley works well.
Make sure it's angled with the cutting edge behind the direction you are scraping, so you don't end up taking wood off rather than just the excess adhesive. And always direction of grain.
/ > bad diagram but explains it.... I think ?
joeylough
  • One hit wonder
« Reply #4 on: August 17, 2012, 02:33:57 PM »
thanks chaps, im having a got with a stanley at the moment. Its a taking a while though.
@joey_lough
SaadIjaz
« Reply #5 on: August 17, 2012, 03:05:50 PM »
A simple method I use is to get fine sanding paper and sand it down until just bits of strings remain.. This can then be hand picked.. Put a light coating of oil after to ensure moisture remains intact since you have sanded the edges a little.
The superior man is modest in his speech, but exceeds in his actions.
trypewriter
« Reply #6 on: August 17, 2012, 03:45:18 PM »
Acetone (nail varnish remover) can sometimes help.
iand123
« Reply #7 on: August 17, 2012, 03:46:21 PM »
Always used white spirit for this
SkipperJ
CBF gave me BAD real bad!
