Mongoose Twenty20 Cricket Bat
Pages: [1] 2 3 ... 12
Author Topic: Mongoose Twenty20 Cricket Bat  (Read 33969 times)
hit4six
  • Trade Count: (+35)
« on: May 22, 2009, 07:42:42 AM »
Just watching the sports news on BBC this morning? they are reviewing the mongoose twenty20 bat. It has an extra long handle (around 4 inches longer, blade 4 inches smaller) and it gives more wood in the hitting area. According to the reporter, it picks up like any other bat. The website for mongoose isnt up and running just yet, but its certainly a brilliant idea. Any views on this....
« Last Edit: May 22, 2009, 09:15:57 PM by hit4six »
cricket-master
Re: Mongoose Twnety20 Cricket Bat
« Reply #1 on: May 22, 2009, 08:13:36 AM »
« Last Edit: May 22, 2009, 08:04:28 PM by cricket-master »
SAF Bats
    • San Andreas Fault
« Reply #2 on: May 22, 2009, 08:51:49 AM »
one word "baseball"
Email: cricket@safbats.co.uk
ianbuchanan
« Reply #3 on: May 22, 2009, 09:16:27 AM »
two words: ouchie fingers!!
aidy1098
  • aidy1098
« Reply #4 on: May 22, 2009, 10:07:33 AM »
awsome i want one!!!!!
Fail to Prepare, Prepare to Fail... Me
Tom
    • www.cricketinsight.co.uk
« Reply #5 on: May 22, 2009, 10:52:35 AM »
Tom
« Reply #6 on: May 22, 2009, 10:54:32 AM »
Interesting pic here, looks almost to be laminated.
They also do a 1 inch smaller blade bat without splice. I'm guessing it's Hunts doing their bats too.
« Last Edit: May 22, 2009, 10:56:15 AM by Tom »
hit4six
« Reply #7 on: May 22, 2009, 10:55:31 AM »
Apparently its going to be used this week in a twenty20? Quite interested to see how it goes!
SillyShilly
« Reply #8 on: May 22, 2009, 10:57:44 AM »
If it's laminated, and very obviously it is, then surely they are not allowed to use these bats in professional cricket
aidy1098
  • aidy1098
« Reply #9 on: May 22, 2009, 10:58:20 AM »
its so expensive tho
SAF Bats
    • San Andreas Fault
« Reply #10 on: May 22, 2009, 12:27:17 PM »
Just reading through the pdf on their web page!!!!
edit_1:
First thing to note... tested against a woodworm!!!!
Second thing I'd ask is was the conventional bat [Woodworm] knocked in - [does the mongoose need knocking in and was that?]
more updates soon!!!!!
edit_2:
Moment of Interia- not sure if anyone has read my blog but it says swing speed is faster on the mongoose -  but in short
The Low Toe Theory - Ummm you're on a merri-go-round and you stand at the end then your weight is propelled around faster [greater momentum] then if you stand in the middle. By moving the weight of the bat further down it has greater momentum then if it is was distributed around the blade….
[ http://www.cricket-stuff.co.uk/?p=161 ]
edit_3 -
Then it bangs on about the Mongoose bat being stiffer... but it seems that it has the same vibration qualities of the a normal blade.  Virbration means energy loss and therefore less energy on batted ball speeds....  So no real benefits from blade stiffness
So the only real benefit is bat swing speed and that has been compromised due to the pickup being heavy.....
Sweet spot - it says it says it is the same.... but there are 2 ommisions in the PDF that would have helped out with this and that is Centre of Precussion and Coefficient of Restitution
- Ok something quick on both Coefficient of Restitution [CoR] you can try this at home. Drop a ball from a fixed height onto the cricket bat and measure the rebound height of the ball - CoR is the square root of rebound height divided by Original height. [this just gives you a number]. But you will see / measure a rebound difference between two cricket bats. CoR is dependant on a number of things
Centre of percussion [CoP] - hang a bat where you normally hold it and hit it with a mallet. At the point it swings like a pendulum that is the CoP. Or when playing with it when the ball hits the cricket bat at a point that it neither pushes your hands forwards or backwards
--- Also noticed mongoose bats are all heavier then the woodworm bat as well.... [ http://www.cricket-stuff.co.uk/?p=15 ]
-- Thats it.....
« Last Edit: May 22, 2009, 01:06:31 PM by Norbair »
Tom
« Reply #11 on: May 22, 2009, 02:38:46 PM »
« Last Edit: May 22, 2009, 09:06:22 PM by Tom »
ianbuchanan
« Reply #12 on: May 22, 2009, 03:28:49 PM »
i think you would have to be either a very god player to middle a ball with this bat, or play on some very evenly bounced wickets
barry1
« Reply #13 on: May 22, 2009, 03:30:20 PM »
All I can say is what is the world of cricket coming to!!!!! I wouldn't fancy Dale Steyn or Brett Lee bouncing me with a big hockey stick in my hand
raymond
« Reply #14 on: May 22, 2009, 06:04:50 PM »
I wonder if they can get 2 bats out of a single cleft?
