Author Topic: Bat spine  (Read 2865 times)
THERUBIN
Bat spine
« on: November 15, 2012, 06:35:18 AM »
If you look at Salix POD and Falx bats. The Pod have a high thin spine and the Falx has the opposit.
Can people understand, what im trying to say ?
What difference does it make ?
« Last Edit: November 15, 2012, 08:47:48 AM by THERUBIN »
THERUBIN
Re: Bat spline
« Reply #1 on: November 15, 2012, 06:36:27 AM »
I'm not talking about the CTS or CTE...
Vantage_Cricket
Re: Bat spline
« Reply #2 on: November 15, 2012, 06:45:41 AM »
Are you talking about the concaving in the Pod?
Canners
  • go hard or go home
Re: Bat spline
« Reply #3 on: November 15, 2012, 07:27:42 AM »
I think we're talking about spine height here. The falx will have a higher spine due to the concaving, if the edge size remains constant in both bats along with willow density and  weight then a concaved bat will always have a higher spine than said bat with no concaving.
THERUBIN
Re: Bat spline
« Reply #4 on: November 15, 2012, 08:18:55 AM »
On the POD picture, it says radical sanding and the Falx says convex sanding
Ryan
  • Trade Count: (+17)
Re: Bat spline
« Reply #5 on: November 15, 2012, 08:42:50 AM »
Convex is the opposite of concaving so a convex profile will be rounded rather than concaved like the pod.  The spine will be generally be higher in the pod due to the willow volume removed through concaving.
THERUBIN
Re: Bat spine
« Reply #6 on: November 15, 2012, 08:51:02 AM »
And why have it higher ?
My toughts are, that the sweepspot, will be smaller, because you need to hit the ball, right in the middle of the bat, instead of the convex profile, would have a wider sweepspot.
But then the Pod would have a lighter pick up and maybe better balance..
Could that have anything to do with it ?
ammo
Re: Bat spine
« Reply #7 on: November 15, 2012, 09:01:33 AM »
In the pod the sweespot would not be as wide whilst in the flax you would get a wide sweet spot
Ryan
Re: Bat spine
« Reply #8 on: November 15, 2012, 09:14:27 AM »
This has been discusses numerous times. Its probably worth using the search function and reading what norbs, doc bolcon and Tim's posted about concaved and convexed profiles.
Canners
Re: Bat spine
« Reply #9 on: November 15, 2012, 11:19:38 AM »
well said
Ryan
Re: Bat spine
« Reply #10 on: November 15, 2012, 11:38:39 AM »
Dr Bacon even :)
trypewriter
Re: Bat spine
« Reply #11 on: November 15, 2012, 11:39:22 AM »
If you are specifically talking about Salix bats, in my experience you need to look at them on a bat to bat basis, as there can be subtle differences between different blades of the same model.
for example, if you watch this, you will see that one Pod is concaved, the other is convex.
