Author Topic: 2012 CLEARANCE  (Read 2490 times)
THERUBIN
2012 CLEARANCE
« on: November 20, 2012, 08:06:03 AM »
With all the 2012 models on clearance sale, I think this is a good time, to look for next seasons match bat.
The problem is, that I play cricket in Denmark, so I have to buy all my equipment on the internet and that could be hard enough, to find the right bat..
I'm going to the top of the range, of the shell bats..
My specs are mid to mid/high middle, light pick up and I'm not much into does high thin spines, so not to much radical sanding.
So far, the bat that I have found, are a Kookaburra Recoil, but I'm not 100% sure about it..
Any inputs about what brand and model i should look for ?
cheers
12man
Re: 2012 CLEARANCE
« Reply #1 on: November 20, 2012, 08:19:23 AM »
Spanky
Re: 2012 CLEARANCE
« Reply #2 on: November 20, 2012, 08:28:49 AM »
Personally I would be tempted to look at Salix if you want an off the shelf bat. They don't seem to have as much concaving as some other brands.
What weight bat are you looking for?
THERUBIN
Re: 2012 CLEARANCE
« Reply #3 on: November 20, 2012, 08:53:24 AM »
So what model have the right middel then ?
2.10 ish
Re: 2012 CLEARANCE
« Reply #4 on: November 20, 2012, 08:57:44 AM »
Most are mid to high I think - Pod may be best-suited to your specs. Or Strike if you want something a little different http://www.talentcricket.co.uk/salix_cricket_bats_2012/salix_strike_performance_cricket_bat/c51p1424.html
« Last Edit: November 20, 2012, 08:59:44 AM by Alvaro »
Spanky
Re: 2012 CLEARANCE
« Reply #5 on: November 20, 2012, 09:05:38 AM »
Personally I would say the Salix Pod, Falx or Strike would suit your spec.
However this is just my opinion as you said you wanted an off the shelf bat.
Vantage_Cricket
Re: 2012 CLEARANCE
« Reply #6 on: November 20, 2012, 09:15:57 AM »
have a look here - http://vantagecricket.co.uk/cricketbats.php to see if anything suits you.
Re: 2012 CLEARANCE
« Reply #7 on: November 20, 2012, 10:35:27 AM »
Pro Direct Cricket have some good deals on Salix bats as a couple of us bought some recently. Pics are under ebay bargains section from memory
Re: 2012 CLEARANCE
« Reply #8 on: November 20, 2012, 10:42:12 AM »
Some of those vantage sticks look right up your street mate!
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: 2012 CLEARANCE
« Reply #9 on: November 20, 2012, 10:42:54 AM »
The lithium looks like what he's after
