Author Topic: Need some help...  (Read 1867 times)
The Island Cricketer
Need some help...
« on: November 24, 2012, 12:55:37 PM »
Hi there, I wanted to take the scuff sheet off my bat and give it a bit of tlc for the winter (scuff has been on there for a year and a half ish) I peeled of the scuff sheet to find the normal adhesive still on the face, although I noticed that these shards or curls of wood have been peeling off the blade, and have left little grooves where they used to be. Do I glue them back down or cut them off? Here are some pictures. Thanks  8)
http://i1067.photobucket.com/albums/u425/TheIslandcricketer/2012-11-24124612.jpg
http://i1067.photobucket.com/albums/u425/TheIslandcricketer/2012-11-24124548.jpg
http://i1067.photobucket.com/albums/u425/TheIslandcricketer/2012-11-24124532.jpg
« Last Edit: November 24, 2012, 12:57:46 PM by The Island Cricketer »
12man
Re: Need some help...
« Reply #1 on: November 24, 2012, 01:00:04 PM »
if you heated the scuff with a hairdryer thats less likley to happen
« Reply #2 on: November 24, 2012, 01:00:36 PM »
Your supposed to pull the scuff sheet across the grains in future mate :/! Otherwise that happens, instead of from toe to handle, go from edge to edge
Vantage_Cricket
« Reply #3 on: November 24, 2012, 01:01:56 PM »
It looks like you've also taken the scuff sheet off with the grain of the blade. you should always take scuff sheets off against the grain to stop these things happening.
I would say the best thing to do with these is to sand them down and make it as even as you can and then re-apply a new scuff sheet.
« Reply #4 on: November 24, 2012, 01:05:33 PM »
Aw damn, I never knew you had to do that ! :(
Thanks anyway guys
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #5 on: November 24, 2012, 05:55:15 PM »
I would sand the face as smooth and flat as poss before putting a new scuff sheet on. Don't forget to go across the grain in future!
