Author Topic: Sandpaper  (Read 9044 times)
Blazer
  • Team Anti - Concave !.
Sandpaper
« on: November 25, 2012, 01:27:27 PM »
Can wet and dry sandpaper be used for sanding down bats ?.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_162774_langId_-1_categoryId_255242
I am struggling to get sandpaper over 320 grit for woodwork.
Re: Sandpaper
« Reply #1 on: November 25, 2012, 01:32:13 PM »
It says it can be used wet or dry, and I assume you want to use it dry. ;) It should be fine, but I think you only really need about 600 grit. Apparently DIY stores don't really do grits above 320, so you may have to go to a more specialised store/site! :)
Blazer
Re: Sandpaper
« Reply #2 on: November 25, 2012, 01:37:11 PM »
Cheers pal, was a bit confused as I thought they can only be used on metal.
« Last Edit: November 25, 2012, 01:38:44 PM by Blazer »
Beachcricket
Re: Sandpaper
« Reply #3 on: November 25, 2012, 01:40:58 PM »
You can get 600 from B&Q, it's wet dry silicon carbide based paper.
Re: Sandpaper
« Reply #4 on: November 25, 2012, 01:48:45 PM »
Ah right haha. :P I think it's just what the sandy granules on the paper are made out of! I use metal oxide sandpaper to sand my bats, and find that 320 is normally enough! I used to use 180, and that seemed alright, but might start using 600! 8)
Blazer
Re: Sandpaper
« Reply #5 on: November 25, 2012, 01:56:50 PM »
Thanks pal. Would you be able to post the link please ?. I can't find any information about grit. All i could find was this
http://www.diy.com/nav/decor/decorating-supplies/abrasives/sand_paper/-specificproducttype-fine_grade_sandpaper/Oakey-Between-Coats-Extra-Fine-Sandpaper-8-Sheets-280-x-230mm-9373469?skuId=9674174
Blazer
Re: Sandpaper
« Reply #6 on: November 25, 2012, 02:00:07 PM »
I didn't even know the existence of sandpaper grit above 320 lol .
Blazer
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Sandpaper
« Reply #9 on: November 25, 2012, 07:20:17 PM »
Screwfix also do 320+ grit wet and dry paper.
smokem
Re: Sandpaper
« Reply #10 on: January 04, 2013, 05:07:26 PM »
Sorry to dig up an old topic but I actually prefer to use wet and dry. Reason being that you can wet it and de-clog the sandpaper. Of course you will have to wait until its dry to use it again but at least you don't end up with a bin full of sandpaper just to do a refurb. Just my personal preference...
Re: Sandpaper
« Reply #11 on: January 04, 2013, 06:59:37 PM »
You can just get a rubber block which you rub over the sandpaper to clear the clogging out. Makes the sandpaper last alot longer
Re: Sandpaper
« Reply #12 on: January 04, 2013, 07:14:50 PM »
I have some 1000 grit somewhere, not really necessary above about 500 in my opinion, especially considering most refurbs i do are followed up with a scuff sheet, if the back of the bat is a bit ropey its nothing a wax and a quick buff wont smooth over.
Blazer
Re: Sandpaper
« Reply #13 on: January 04, 2013, 07:31:46 PM »
I managed to obtain sandpaper up to grit 2500 , but found out using them to that extent did not make much of a difference. I agree with you about sticking with 500 grit with waxing and buffing.
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Sandpaper
« Reply #14 on: January 04, 2013, 07:33:02 PM »
I usually finish off with some 1200 grit wet and dry
