Pages: [1] 2 3 4
Author Topic: Movember Ask the Bat Maker  (Read 13296 times)
safbats
« on: November 27, 2012, 11:52:36 AM »
Limit this to 20 questions
If you like this thread donate something even small amounts help! [paypal is accepted by the guys at Movember land]
http://mobro.co/andysafbats
Fire away ....
« Last Edit: November 27, 2012, 05:17:02 PM by safbats »
Number4
Re: Movemeber Ask the Bat Maker
« Reply #1 on: November 27, 2012, 11:58:11 AM »
Is there a best "grain:ping" ratio from your experience and in your opinion?
« Reply #2 on: November 27, 2012, 12:03:02 PM »
What is the best way to manage unwanted vibration in the creation of a bat?
i12breakfree
« Reply #3 on: November 27, 2012, 12:04:03 PM »
Oversize pro grade light weight clefts - myth or truth ?
If they exist, do you use them ?
« Reply #4 on: November 27, 2012, 12:18:20 PM »
does it matter which end of a cleft the handle goes - and if not, how do you choose?
Number4
« Reply #5 on: November 27, 2012, 12:20:06 PM »
Everyone knows the handle goes in the top Buzz ;)...
« Reply #6 on: November 27, 2012, 12:22:52 PM »
Why not make a totally flat brick on a stick paddle, and not bother trying to shape a spine, scoop, twin scoops, concaving, etc? Would it make any difference?
tugga
« Reply #7 on: November 27, 2012, 12:26:11 PM »
What sort of sound should you be looking for when you tap up a blade? (ither with mallet or finger)
« Reply #8 on: November 27, 2012, 12:29:56 PM »
Could you do audio files of good sounding bat/cleft vs poor sounding one? where is the pic of your Mo
safbats
« Reply #9 on: November 27, 2012, 12:31:25 PM »
around 8 Grains is the easiest to get right
I say that because the pressing leaves you with enough volume to work with to make a good size bat and it reacts well to the press as well so you arent deadening the willow from the pressure
Once you move up and down from here your really need to change the way you do stuff...
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #10 on: November 27, 2012, 12:32:44 PM »
What tool do you find most useful/biggest pain in the rear when making a bat?
Manormanic
« Reply #11 on: November 27, 2012, 12:35:06 PM »
Supplementary question - how?
safbats
« Reply #12 on: November 27, 2012, 12:41:10 PM »
Jasus! That is question and a half!!!!
Ok ummmm Cricket Bat willow is a natural fibre reinforced composite!
We know the vessel run through the cricket bat from shoulder to toe.  We can see those vessels are layered in the willow itself and mixed with the grain.  This longitudinal nature of the willow fibres determine some really important factors in cricket bats. That is, in this vessel orientation and layering we get stiffness.
So what am I talking about, well elasticity and bending frequencies.
Due to the vessel layering it affects those aspects of the cricket bat, this leads to cricket bat performance. I wont go to far into this but here is a  snippet.  They are both intertwined here, elasticity and bending frequencies.
Ok bending modes of the bat,  this is based on the bat shape [profile] and if you take into consideration the excitation range [vibration] of a cricket bat based on impact we know you can raise or lower the bending mode frequencies of a bat based on mass of the blade and handles, in layman terms a gain in performance.
But now you can see the willow itself, the vessel layering and the grain effect this as well and why the pressing of the blade is so important as this adds another composite layer.
So in short pressing, its profile shape and handle choice
pain in the ass hey!
« Last Edit: November 27, 2012, 05:16:12 PM by safbats »
safbats
« Reply #13 on: November 27, 2012, 12:46:09 PM »
Oversize clefts - Truth [not readily available from the larger willow merchants, Matt H4L splits and creates his own, Matt you owe me for the plug]
Light weight Clefts - Truth [Rare and will be even rarer in oversize clefts due to the number being produced]
Do they exist, potentially in Oversize but more common in std cleft cut sizes
Based on experience 1st class cricketers will want to get big looking bats for the weights they asked for.
Do I use them, No for Oversize but I do get light weight std size clefts
« Last Edit: November 27, 2012, 05:15:16 PM by safbats »
safbats
« Reply #14 on: November 27, 2012, 12:50:29 PM »
Bat Makers choice!
Generally based on looks for the handle end, so any pin knot, stains, grain orientation etc will be the end chosen for the handle
Sometimes I like to leave a small butterfly stain in the toe area as it is nice and strong and stops toe breakages better.
« Last Edit: November 27, 2012, 05:14:21 PM by safbats »
Pages: [1] 2 3 4
