Author Topic: Shorten handle  (Read 2143 times)
adam1312
Shorten handle
« on: December 30, 2012, 11:39:43 AM »
How can I shorten the handle, because I hold the bat low down and have some od the handle getting in the way at the top but the bale is an okay size and I have just bought it
Re: Shorten handle
« Reply #1 on: December 30, 2012, 11:41:41 AM »
Saw off the knob.
But be careful, it will affect the balance.
Re: Shorten handle
« Reply #2 on: December 30, 2012, 11:59:39 AM »
I cut the knob off on top then used analogies tape to create a new knob it sure does effect balance I did not like it on the on the one I did
Re: Shorten handle
« Reply #3 on: December 30, 2012, 12:09:15 PM »
I understand the swears filter, but knob?
Everyone's got one on their handle!
Number4
Re: Shorten handle
« Reply #4 on: December 30, 2012, 12:12:32 PM »
Re: Shorten handle
« Reply #5 on: December 30, 2012, 12:39:27 PM »
ok, I have relaxed the knob from the filter, please use the new power wisely!! you can't use knob without the k.
Manormanic
Re: Shorten handle
« Reply #6 on: December 30, 2012, 12:40:09 PM »
Careful, it might go to people's heads...
Lukeys Sports
Re: Shorten handle
« Reply #7 on: December 30, 2012, 12:58:48 PM »
If you cut the handle the balance of the bat will be gone!
adam1312
Re: Shorten handle
« Reply #8 on: December 30, 2012, 02:39:39 PM »
If the bat has a high middle and I'm using two or 3 grips, how much will the balance change?
i12breakfree
Re: Shorten handle
« Reply #9 on: December 30, 2012, 02:41:53 PM »
Learn from the Pros
Re: Shorten handle
« Reply #10 on: December 30, 2012, 02:42:47 PM »
It has not changed it that much on mine mine has a high middle but it does feel different for sure but I have got used to it
adam1312
Re: Shorten handle
« Reply #11 on: December 30, 2012, 02:47:31 PM »
What did you use, did you just saw some off or did you sand it down?
Re: Shorten handle
« Reply #12 on: December 30, 2012, 02:48:42 PM »
I get some pictures up I just sawed it off the whole (No Swearing Please) end
Vulcan Cricket
Re: Shorten handle
« Reply #13 on: December 30, 2012, 03:42:30 PM »
get cutting lad if it dont feel right then you can just get a ssh fitted with the knob on the end lol  :( ;)
Manormanic
Re: Shorten handle
« Reply #14 on: December 30, 2012, 03:49:36 PM »
Yuvi looks like he's had a different k cut there...
