Pages: [1] 2 3
Author Topic: Measure your edges...  (Read 5733 times)
« on: January 08, 2013, 07:44:13 PM »
Given the odd edges on Paul's A41, has anyone else measured both edges on their bats? If you have, what have you found?
roco
Re: Measure your edges...
« Reply #1 on: January 08, 2013, 07:45:20 PM »
On my bats there
40mm 40.5mm Aldred
41mm 43mm    Bb
43mm 43.5mm ca
Is that ok??
« Last Edit: January 09, 2013, 12:20:21 PM by roco »
toenails97
« Reply #2 on: January 08, 2013, 07:46:54 PM »
My Salix around 25ml edges however it still goes like a beast!
Johnny
« Reply #3 on: January 08, 2013, 07:47:40 PM »
On my bats there
40mm
41mm
43mm
You bat has 3 edges? ???
« Reply #4 on: January 08, 2013, 07:47:50 PM »
Your bat has 3 edges Roco? I knew u were an odd one...triangular bats, 3 times the faces, 3x the lifespan! Clever stuff ;)
« Reply #5 on: January 08, 2013, 07:48:07 PM »
Haha beat me to it Johnny :)
roco
« Reply #6 on: January 08, 2013, 07:48:14 PM »
Ok I get you now will modify
As eldest would say
Epic fail haha
Karan62
  • Colts
« Reply #7 on: January 08, 2013, 08:01:41 PM »
mother of god imma gonna have to sue for this ...
35mm and 35.1mm
Sam
« Reply #8 on: January 08, 2013, 08:09:40 PM »
Would be quite an interesting bat to be honest if you could keep the weight down  :D.
« Reply #9 on: January 08, 2013, 10:10:39 PM »
Did a quick measurement on three bats. Results are from an MSR, an Instinct and a Dynadrive.
The results are...
33mm and 33mm
34mm and 34mm
36mm and 39mm
All measured at the same distance from the toe per bat. Can you guess which bat is which?
alexhilly1492
« Reply #10 on: January 08, 2013, 10:54:56 PM »
adidas incurza pro: 26mm and 26mm
BB: 7-4-9-5, 7.3-0-29-5
ItsJustCricket
    • Its Just Cricket
« Reply #11 on: January 08, 2013, 10:55:48 PM »
The results are...
33mm and 33mm
34mm and 34mm
36mm and 39mm
The Dynadrive will be the 36mm and 39mm, not sure on the others.  Interesting - what does this say about GN's bat making?!
« Reply #12 on: January 08, 2013, 11:32:12 PM »
The results are...
33mm and 33mm
34mm and 34mm
36mm and 39mm
How about your Saf, as that is a hand made uk bat
ursmasti
« Reply #13 on: January 09, 2013, 04:53:31 AM »
slazenger v12 has 37mm edges weight 2.9
Slazenger v1200 40mm edges weight 2.8
Laver and wood reserve 40mm edges weight 2.10
« Reply #14 on: January 09, 2013, 06:03:23 AM »
Hades is 32 & 33
Laver is 28 on both
B3 (CNC remember, so should be the same on both), 34 & 35!
And Paul is correct, the Dynadrive has the highest discrepancy.
Pages: [1] 2 3
