Pages: 1 2 [3] 4 5 6
Author Topic: Sticker and Scuff Sheet Removal - A concise guide  (Read 147636 times)
Rampage
Re: Sticker and Scuff Sheet Removal - A concise guide
« Reply #30 on: March 07, 2014, 10:22:08 AM »
thanks for the info
BigBlueMachine
« Reply #31 on: March 20, 2014, 09:05:59 AM »
Another product to remove sticky residue is De-solv-it. It has a natural citrus base which shouldn't affect the wood if you are worried about using Turps or White spirit. I got mine from Bunnings in Aus, but I'm sure you could source the equivelent from Homebase or B&Q for those in the UK.
Worked really well, just applied it with an old dry rag. Then after rubbing in for a bit I used the back of a butter knife to scrape off.
« Reply #32 on: March 20, 2014, 09:58:45 AM »
Yup, I used that.
tejasapatel
« Reply #33 on: March 21, 2014, 06:02:07 PM »
Last year I got a pre-knocked bat that wasn't really knocked in. I didn't get a chance to use the bat as I hated it and usually picked up one of the team bats. Since the bat was sitting in my garage through the long winter decided to oil and knock it myself.
Removed the stickers and scuff sheet with hair dryer and a product called Goo-Gone pro similar to de-solv-it. I was able to get rid of all of the gum with no trouble and went ahead with a fine 180 sand paper and sanded the bat a little.
At least some oiling tonight and knocking in over the weekend will make this bat useful enough for pre-season practice before I get a new bat.
Thanks for all the great tips.
- Ian Botham
i12breakfree
« Reply #34 on: March 28, 2014, 01:04:56 PM »
Cleaning up my blank bat this week
Hair dryer and goo-gone have been a big help
Wish I had pics of before
Here is one after sanding and oil
Jenko
« Reply #35 on: March 28, 2014, 11:05:40 PM »
Great thread. I'm planning on refurbing my two lavers during the off season. Both have extra tec facing which I've never really liked on my bats so will be nuding them up completely stickers and all.
Centurion
« Reply #36 on: March 31, 2014, 03:10:50 PM »
Its always a sticky situation lol  :D
(no pun intended)
W.G. Grace
kal_m
« Reply #37 on: April 01, 2014, 03:22:52 PM »
My MB Malik before and after removing the stickers, sanding and oiling...
Aspire and Achieve
Giraffe208
« Reply #38 on: May 03, 2014, 08:44:18 AM »
I'm about to refurb something I acquired on the cheap BUT.....the bat had a face sheet the entire length of the face, including going over the stickers. Now it's a Salix and wanting to keep the stickers I managed to peel off the face sheet and keep them intact. However they are obviously sticky. What's the best thing to remove said stickiness?
wayward_hayward
« Reply #39 on: May 03, 2014, 09:40:05 AM »
I'm refurbing right now and just gone through the sticky removing,  use some linseed oil on the stickers, works a treat.
Twitter @wayward_hayward
Nmcgee
« Reply #40 on: May 03, 2014, 12:32:01 PM »
Double-D eucalyptus oil. Extremely effective.
Back yourself.
Andythomo21
« Reply #41 on: December 02, 2014, 06:53:03 PM »
Hi, great thread this.  I've got a nice Charlie French bat with a fibre glass scuff sheet that I would like to remove.  Do I fellow the same steps as removing any scuff sheet or are there any hints/tips for specifically removing fibre glass scuff sheets?
Thanks.
« Reply #42 on: December 03, 2014, 06:15:18 AM »
Fibre scuff sheets typically don't come off as easily.  I'd recommend following the steps as outlined,  using heat to try and lift the sheet,  but you are likely to need to use either white spirit or sanding to remove what remains.  Typically fibre sheets 'rip' inconsistently along the fibres so it doesn't all come off in one piece.
« Reply #43 on: December 15, 2014, 07:17:58 PM »
will using the blow dryer minimize chances of wood coming off with the sheet?
TBONTB
« Reply #44 on: December 15, 2014, 07:28:05 PM »
Almost certainly! I did not use it enough and got a tiny bit of take up but I am sure if I did it would have been fine and go really slow!
