Laminated Bats in Cricket
Pages: 1 ... 3 4 [5] 6
Author Topic: Laminated Bats in Cricket  (Read 38040 times)
SillyShilly
Re: Laminated Bats in Cricket
« Reply #60 on: June 08, 2010, 09:32:57 AM »
PVA seems to be the weapon of choice for many people, in the handle this is just fine, not sure about the laminated layer though - i can see no reason why it should be any different?
I've only seen and used a few laminates so my knowledge is pretty poor - i suppose the ihsan pictured is rather abviously laminated, whereas the one  i have it is almost impossible to recognise, i suppose it's down to the skill of the batmaker.
Vantage Cricket
« Reply #61 on: June 08, 2010, 09:43:41 AM »
I spoke to a recently released county player this weekend and he was saying the majority of the side he was playing for used laminated bats with upto 3 layers... Im not naming names though but they were very high profile players!
Uzi Sports
  • Trade Count: (+28)
    • Uzi Sports &  AS Sports
« Reply #62 on: June 08, 2010, 09:55:41 AM »
I agree with that, as I know quite a few players who use these bats.
Regards
Asad
Beachcricket
« Reply #63 on: June 08, 2010, 10:03:12 AM »
Vantage - you mentioned before someone turned up to your workshop with a bat with a thin sheet of rubber in it. I thought they were just wood and the stiffness created the power?
Is the face layer hard and the subsequent layers lighter or softer.
James Laver uses a "aliphatic glue" for the handles according to L&W facebook page.
n80krr
« Reply #64 on: June 08, 2010, 10:13:43 AM »
Thats just what I was thinking Beach. I've got access to polyurethane foam and also a selction of rubber compounds. so was wondering if i could hollow out a bat, using a cnc router then fill it with a product then put a veneer on the top face?
Ok Ok I'll shut up
« Reply #65 on: June 08, 2010, 10:23:32 AM »
Surely the first class umpires must be noticing this and saying something?
forget J-Lo's bum - with that technique you could have a bat with the bum the size of serena williams'
n80krr
« Reply #66 on: June 08, 2010, 11:14:10 AM »
think that curvature is just abit too much, lol.
Ok Ok I'll shut up
norbs
« Reply #67 on: June 08, 2010, 12:05:38 PM »
You and your CNC machine....
How are you going to get any performance gains for your bat with PU and rubber compounds and some veneer?
« Last Edit: June 08, 2010, 12:09:11 PM by norbs »
« Reply #68 on: June 08, 2010, 12:08:27 PM »
Buzz - excellent example of curvature!  :D
n80krr
« Reply #69 on: June 08, 2010, 12:12:16 PM »
So theoretically speaking, if i were to get a bat (pre made), take the front face off (around 10mm), make a groove (not sure on size), place some bouncy material in the groove(rubber) then place a small piece of willow (higher quality then the donor bat) back on the face and laminate it using some adhesive and a lot of weight. You reckon I'd have made a decent bat for catching practice?
I know boys and their toys, I'm just getting use to using it so right now I'm practicing on anything and everything. Thought might as well try something that I might use.
Just trying to think of springy materials that I could access to fill a cavity within a laminated bat.
Ok Ok I'll shut up
SillyShilly
« Reply #70 on: June 08, 2010, 12:16:13 PM »
why springy, why not rigid?
n80krr
« Reply #71 on: June 08, 2010, 12:18:19 PM »
thinking of rubber as it holds a rigid form but has some give. Or would perhaps some resin and something be a better option much more rigid. I was afraid of breaking the material on high impact.
Ok Ok I'll shut up
norbs
« Reply #72 on: June 08, 2010, 12:19:31 PM »
Recommend you buy a Skyer
« Reply #73 on: June 08, 2010, 12:31:06 PM »
I picked up a pink skyer off ebay for around £30 and the ball goes like a trampoline off it!
Makes catching practice better fun!
n80krr
« Reply #74 on: June 08, 2010, 12:46:30 PM »
thanks pete, I don't really want to buy something I could possibly make. It's not just to have a bat for catching practice it's to start to understand more about what makes a good bat. Thats why I posted in the Bat Making forum.
Ok Ok I'll shut up
