Author Topic: Video of me in the nets  (Read 4015 times)
Howzat
« on: June 17, 2009, 04:46:43 PM »
Not too bad, I think my batting has come on a lot since last year! Bearing in mind I will be batting around 8 or 9.
Apple
Re: Video of me in the nets
« Reply #1 on: June 17, 2009, 04:50:13 PM »
hes as good as the elders say . . . .
Howzat
« Reply #2 on: June 17, 2009, 04:54:34 PM »
Not a clue what that means but thanks for watching lol
BigBoyChado
« Reply #3 on: June 17, 2009, 04:59:11 PM »
not bad not bad. the bloke with his shirt off the guy who got 50 against us ?
Apple
« Reply #4 on: June 17, 2009, 05:01:00 PM »
leo what club do u play for/
Howzat
« Reply #5 on: June 17, 2009, 05:01:59 PM »
Yeah good spot Charlie... he said you were a good bat very technically correct, although he said he scored his 50 off 12 overs or so and it took you at least 25 :p
BigBoyChado
« Reply #6 on: June 17, 2009, 05:09:02 PM »
yeah but I didn't get fed full tosses and half trackers. i had to work for my runs ;).
« Last Edit: June 17, 2009, 05:11:11 PM by BigBoyChado »
raymond
« Reply #7 on: June 17, 2009, 05:25:03 PM »
I think you should try to keep your shoulders and hips in line as your hips are twisting to the leg side, which i think is causing you to slice your drives a bit... which will lose power. Its hard to really tell due to the angle.
Howzat
« Reply #8 on: June 17, 2009, 06:03:25 PM »
Thanks Raymond I'll bear that in mind, if anyone else has any advice just post :)
raymond
« Reply #9 on: June 17, 2009, 06:07:27 PM »
Also seem to be pushing at the ball, wait later and then whack it!
Coach
« Reply #10 on: June 17, 2009, 06:07:59 PM »
Leo i would try to reduce the amount that your head moves around as it seams to quite a bit if you are stiller you should get a few better contacts and i agree about the hip twist, slight changes that will make a big differance to your game
Watsontotty
« Reply #11 on: June 17, 2009, 06:46:42 PM »
Not really the best angle and not easy to see what you were doing right or wrong to be honest with you. You dint play many shots in the video and the ones you did either took the edge or popped in the air to cover but as i said i couldn't get a close enough look to suggest why.
aidy1098
  • aidy1098
« Reply #12 on: June 17, 2009, 09:41:39 PM »
it isnt working
Fail to Prepare, Prepare to Fail... Me
eaowbear
« Reply #13 on: June 18, 2009, 07:37:20 AM »
Doesn't seem much wrong to me at all, as you laced a couple through the covers with good balance and have a decent set up, especially for a number 8 or 9!
