Has anyone used a 3lb 3oz+ bat? Please tell me about your experience?
Author Topic: Has anyone used a 3lb 3oz+ bat? Please tell me about your experience?  (Read 3837 times)
wasted_talent
Was just wondering if anyone had ever used a bat weighing more than 3lb 3oz? If yes, did they find the bat performed better due to the sheer about of wood on it? or does the weight not make any difference at all?
fatbats
    • Fat Bats
Re: Has anyone used a 3lb 3oz+ bat? Please tell me about your experience?
« Reply #1 on: January 23, 2013, 10:24:41 AM »
My heavy bat is 3lb2 long blade
A heavy bat has no benefit unless you can use it freely
A few people have had a hit with my bats but few can swing them effectively
Yes with the weight you get more wood so you don't need to lift bat up as high but if your slow with it not much point
mattw
    • PRYZM Cricket
« Reply #2 on: January 23, 2013, 10:29:10 AM »
More mass = more power with the same swingspeed.
However, for me I prefer a lighter bat to get more swingspeed. Heavier bats are more powerful due to the mass of wood, however if you can't use it - it's pointless
« Reply #3 on: January 23, 2013, 10:33:07 AM »
I had a 3lb 4oz bat that was destined for Ronni Irani, before he retired. Upside was anything you put effort into cleared the field. Downside was the pain the following morning from using such a monster. Used to feel like my arms had dropped off. I've also noticed a slow down in bat speed, anything above 2'12 in my case. That said the 3lb 4oz bat had a traditional profile and beautiful pickup which made it feel a little lighter. I eventually had the guys from Kippax shave it down to 2'13-14oz and they left the middle untouched. They shortened the blade a half inch and shaved the shoulders/handle, that was it - 6oz gone!.
mr_wickets
« Reply #4 on: January 23, 2013, 10:34:29 AM »
I used to have a 3lb + bat, which when facing bowling on a slow, low wicket was awsome! Head down, swing through the line and watch it sail! Came a bit unstuck on som quicker wickets with a bit more bounce though!
trypewriter
« Reply #5 on: January 23, 2013, 10:41:21 AM »
Certainly agree with that!
justnotcricket86
« Reply #6 on: January 23, 2013, 10:49:07 AM »
If you're strong enough, use one mate. It's all relative. More wood on the bat obviously, but if you can't control the bloody thing then no point using one.
Manormanic
« Reply #7 on: January 23, 2013, 10:51:55 AM »
got a 3lb 4 B52XL, which absolutely flies.  Wierd thing is I never really notice the weight, only the lack of it when I use something too light!
justnotcricket86
« Reply #8 on: January 23, 2013, 10:53:48 AM »
Must have a nice pick up then mate :)
lastmanstand
« Reply #9 on: January 23, 2013, 11:02:35 AM »
any one seen/used the 4lb slazenger 'training' bat on sports direct??? absolutley massive
Knocking them out for £225 in grade 2 willow. A lot to fork out but could be a laugh. Think Il be sticking to 2'8 long term though
#GFI
wasted_talent
« Reply #10 on: January 23, 2013, 11:04:11 AM »
thank you all for the reply
i think i'd only look to use it on slow wickets or when there is not much time left to settle in and the "slog" is on.
will have to go and try to pick one up at the local shop to see if i can manage it effectively before making a purchase i think.
« Reply #11 on: January 23, 2013, 11:11:07 AM »
what weight bat do you use at the moment. I've heard of Pro's going an oz or two heavier for ODI/T20. I think it it slows your bad speed significantly or restricts your shot choice (ie. you struggle to play cross bat shots), then it's probably too heavy.
Manormanic
« Reply #12 on: January 23, 2013, 11:44:43 AM »
Its okay - I'm just used to using biiiiiig bats!  My lightest is about 2lb13
fatbats
    • Fat Bats
« Reply #13 on: January 23, 2013, 12:36:55 PM »
 That is light isn't it??
My light bat is 2lb14 long blade
piddyunited
« Reply #14 on: January 23, 2013, 04:09:36 PM »
Yer ive just had a blueroom swell 3lb 4 made up by RPC and is the best bat ive had by far. Pick up is fantastic and absolutely love the ping, big profile as well. :)
