Author Topic: Best time to put on a hammer edge?  (Read 2175 times)
DevAussie
« on: January 26, 2013, 12:27:51 PM »
Not sure if people's opinions are different but when would everyone put a protective face on their bats??? I have heard various times mentioned...after oiling, before knocking in...after both those...before both those....
Interested in people's thoughts??
Ams4287
Re: Best time to put on a hammer edge?
« Reply #1 on: January 26, 2013, 12:41:09 PM »
Would suggest oil, leave to dry for a few weeks (not stood up and not in a warm room), then apply a face prior to knocking in.
That's my approach anyway
ItsJustCricket
    • Its Just Cricket
« Reply #2 on: January 26, 2013, 12:50:14 PM »
What we normally do is give the bat one coat of oil.  Don't do two as then the Hammer Edge won't stick as well.  Give the bat 24 hours to dry and then start knocking it in.  A few days later, and just before the knocking in is finished, apply the sheet, and then do about 15 minutes more knocking in with the sheet applied.  This way it makes the sheet stick a bit better, almost as if the sheet itself is knocked in! If you knock in the bat in one day, don't apply the sheet straight away, as the oil needs to have dried for 5-7 days ideally to minimise the risk of the sheet not sticking well.  Hope this helps...
Ryan
  • Trade Count: (+17)
« Reply #3 on: January 26, 2013, 12:57:19 PM »
Mr millichamp advises applying one straight away. It keeps the moisture in the blade. Give the back/ toe and edges a couple of coats of oil,then knock in. If you oil the face you'll have to spend more time knocking in as it opens up the pressed fibres of the willow.
Ryan
farnham_quins_2
« Reply #5 on: January 26, 2013, 01:50:38 PM »
Going to slightly hi jack this thread to ask a related question...
Should you sand, then wax, then oil a bat? Is that the correct order? Or oil then wax..?
Ryan
« Reply #6 on: January 26, 2013, 01:55:35 PM »
You should always sand/wax and maybe oil if needed. However you need to make sure you use a porous wax so the oil can seep through.
jimster
Ryan
« Reply #8 on: January 26, 2013, 02:10:07 PM »
That's down to personal preference but Julian does know what he's taking about.
farnham_quins_2
« Reply #9 on: January 26, 2013, 02:16:51 PM »
Thats what I was going to say, if good enough for Julian then probably good enough for me...
« Reply #10 on: January 26, 2013, 02:20:36 PM »
fletcheruk is that still you?
« Reply #11 on: January 26, 2013, 02:25:01 PM »
No - it's another Ryan with the same avatar  ???
« Reply #12 on: January 26, 2013, 02:26:02 PM »
« Reply #13 on: January 26, 2013, 02:27:59 PM »
You plum!
Ryan
« Reply #14 on: January 26, 2013, 02:29:14 PM »
Haha like it
