Pages: 1 ... 7 8 [9] 10
Author Topic: Buzz's Batting Book PLUS kitchen coaching videos (links in OP)  (Read 165049 times)
sanredrose
Re: Buzz's Batting Book PLUS kitchen coaching videos (links in OP)
« Reply #120 on: April 10, 2017, 11:34:17 PM »
If its of any help
I tend to be all bottom hand attacking  being left handed always looking to  pull and  hook with a normal mid handle grip no need to change. the diamond shape works  for me as  arms are away from my body which helps bat swing shot momentum if that makes sense.
Yes, your explanation makes sense. I had my friends look at the video of Kane Williamson. He plays a perfect pull shot (video duration - first 30 seconds).
https://www.youtube.com/watch?v=W_NsJbm_Z3g
« Reply #121 on: May 19, 2017, 11:24:51 AM »
Ok, I have a small window to do a kitchen coaching session in the next hour or so.
Any suggestions on batting topics?
« Reply #122 on: May 19, 2017, 11:26:47 AM »
@Buzz, how about judging length - watching hand position and release point technique doesn't work for me. In fact, it doesn't work for anyone I know.
So, how do you judge length early enough to get in position early to make clean contact?
« Reply #123 on: May 19, 2017, 11:27:01 AM »
Tips to avoid falling over when playing through the leg side would be particularly helpful for me at the moment!
« Reply #124 on: May 19, 2017, 11:34:00 AM »
Good suggestion, not sure I can do that in the kitchen, but it comes from learned behaviour over time and instinct.
Will definitely be able to do this.
« Reply #125 on: May 19, 2017, 12:11:27 PM »
How to clear long on , off a full bunger
Minimum 80m
« Reply #126 on: May 19, 2017, 12:40:23 PM »
Minimum 80m
Good suggestion, here is one I asked Moeen to do for you
https://youtu.be/6mPG5hGDp2c
And here for @Kulli is the falling over video it also looks at splaying your front foot.
Standard terrible camera work and chopped off head!
https://youtu.be/Y3MZxTBr40Q
Also just found this video. https://youtu.be/jz7LhovatHM
So much good stuff in there on feet movement, going forward and back to spin (or slow medium bowling really)
« Last Edit: May 19, 2017, 01:08:06 PM by Buzz »
« Reply #127 on: May 19, 2017, 02:19:54 PM »
Super video that, shows the clear difference between power hitting and technical strokeplay, the coach in that vodo is opening his front foot and using the power if his hips and glutes to strike the ball a long way.
Important to know both ways to play these days.
Biggie Smalls
« Reply #128 on: May 22, 2017, 09:20:26 PM »
It's also about release time ....earlier suggests fuller , later suggests shorter . Release point works for me and most people i know , so if its not working for you it doesn't mean you can't change that .
Something that helped me years and years ago was to get bowling machine practice whereby I'd ask the feeder to change the length occasionally ( subtly,  when i wasn't looking ) . I'd have a very brief window/moment before the ball was released to assess the tilt/angle of the machine head . Seeing the change in angle gave a great / obvious indication of where the ball would pitch , and this is the closest that a bowling machine has to a release point.  This eyeballing of the tilt/angle started to easily transfer over to gauging actual bowlers release points after a while ...... I  can't explain precisely how this occured other than to say the visualization and feel of one transfered to the other . Might be worth a try .
JB
« Reply #129 on: May 22, 2017, 09:37:17 PM »
Could watch @Buzz's videos all day!! That @Blank Bats that he has is an absurdly nice shape though!! Is this standard or a custom?
« Reply #131 on: October 17, 2018, 05:07:16 PM »
I read this article today about implicit learning. I believe this is the most import skill in coaching...
Please take a read.
http://www.sportsciencesupport.com/implicit-learning/
« Reply #132 on: January 15, 2019, 09:44:59 PM »
A few people have asked about the batting book I have written.
If you are interested in taking a look, it can be downloaded here
http://www.getsomepixels.co.uk/Batting%20book%20v5.pdf
I hope it is useful, please get in touch if you have any questions.
It is still a work in progress in some sections, buy thanks to Paul and Steve (you know who you are! ;)) for your comments
link updated June 2015
updated post with kitchen coaching links:
https://youtu.be/2DiAyEkAt5E grip and diamond
https://youtu.be/LApFGNi42Z0: Hips
https://youtu.be/jVv0jvTwYN4: Posture
https://youtu.be/-FZV1nk1sJ0: Pick up
https://youtu.be/rokwxotanGM: Aligning stance
https://youtu.be/zDXVRZHm4x0: Hitting through the on-side
https://youtu.be/1VR3eX8C1io back foot defensive approach
https://youtu.be/Y3MZxTBr40Q head position and not falling over through the shot
Giving these a pre season bump...
Yorkershire
« Reply #133 on: January 15, 2019, 11:24:25 PM »
Downloaded. Looking forward to reading it.  :)
liscon12
« Reply #134 on: January 15, 2019, 11:37:35 PM »
For a lot of the YouTube links I'm getting a 404 erroe @Buzz
Any ideas why this might be?
