Me bowling - Any advice appreciated!
Author Topic: Me bowling - Any advice appreciated!  (Read 7335 times)
LDifa
Re: Me bowling - Any advice appreciated!
« Reply #15 on: March 12, 2013, 12:08:35 AM »
Chad, get in touch with the Ecb, I am sure they will find you a local coach (fairly local).
I was videoed from behind, from the batters end, and the best angle was side on, looking at where my feet where landing (I bowl offspin)
Kez
« Reply #16 on: March 12, 2013, 12:21:54 AM »
I am also a great believer that fast bowlers get a lot of pace from their glutes - work hard on leg strength and that will help you push your leg through on the crease and maybe generate a little more pace.
Sad biomechanical point here - you want to slow the bottom half of your body down in delivery stride to allow the top half to accelerate at a greater rate to bowl quicker.
EDIT: Note- yes leg strength is need to aid deceleration and not ruin knees/ ankles.
« Last Edit: March 12, 2013, 12:28:42 AM by Kez »
kesoncricket.com
crictech
    • CricTech
« Reply #17 on: March 12, 2013, 04:14:40 AM »
Scrap that, the rest look fine. You do definitely fall over though and your head looks to drop to the off side.
good attacking action. It's hard to tell from a reverse angle camera but when you hit your release point it looks like your head is still slightly back which means you haven't transferred your momentum fully into the delivery. Your head then falls away early as Nickauger pointed out. This could be one reason for not being able to maintain a consistent line.
Try looking down the inside of your arm instead of the outside and keep your eyes level for as long as you can through the action. This should help with the head falling away and the momentum through the delivery stride. You may gain a yard too.
Number4
« Reply #18 on: March 12, 2013, 06:06:12 AM »
Maybe just me but your front foot is landing wide instead of more inline (stump to stump) which is slowing you down and not allowing a full follow through... And your brothers back leg is collapsing when it lands which mean he isn't releasing it as high as what he could be and not getting the bounce and speed he could be getting.
Or I have know idea what I am talking about therefore ignore m comments
Fezballoh
« Reply #19 on: March 12, 2013, 07:40:24 AM »
Having watched you bowl, I'm in the front arm camp, which should force you into lining your body up where you want it to point. But if you reckon it causes you more problems then I would say try and loosen up during your run up, which looks a bit stuttery. Try and make sure that your grip and wrist position are correct if you're having control problems. There are so many things to remember. That's why I've sacked it off to work on my batting instead!
Don't worry about having a 'mixed' action. We need all the variety possible in our game! Besides Bob Woolmer says it aint' no thing to have a mixed action in his big book of cricket which for me is the difinitive big book of cricket. All the batting break downs are done with Kallis modelling, with Donald and Rhodes demonstrating their own strongest suits. It's about £30 but i'm sure someone at your uni will already have one to reference.
Kez
« Reply #20 on: March 12, 2013, 09:39:50 AM »
whats usually said is right but people thoughts on why is wrong.
ie: standing tall to bowl
the reason this is said- to get bowler to brace the front leg for it to as a break around which to torso can rotate.
A scientific fact if to bowlers have the same arm speed but one braces the front leg they bowl quicker.
One lad who bowled pretty quick in his day
kesoncricket.com
Number4
« Reply #21 on: March 12, 2013, 10:05:43 AM »
So in fact standing tall to bowl does help with bounce and speed... Hmmm thought that's what I said... And yes we all know Brett Lee Bowled fast... Wonder if he bowled taller if he could have been faster while still bracing the front leg.. Guess we will never know
Kez
« Reply #22 on: March 12, 2013, 10:26:08 AM »
standing tall hasnt been tested... bracing the front leg increases pace!
kesoncricket.com
Number4
« Reply #23 on: March 12, 2013, 10:52:46 AM »
Glazier PS, Paradisis GP, Cooper SM.
Source
Biomechanics Laboratory, School of Sport, University of Wales Institute Cardiff, UK. pglazier@uwic.ac.uk
Abstract
The main aim of this study was to identify significant relationships between selected anthropometric and kinematic variables and ball release speed. Nine collegiate fast-medium bowlers (mean +/- s: age 21.0 +/- 0.9 years, body mass 77.2 +/- 8.1 kg, height 1.83 +/- 0.1 m) were filmed and reconstructed three-dimensionally. Ball release speeds were measured by a previously validated Speedchek Personal Sports Radar (Tribar Industries, Canada). Relationships between selected anthropometric variables and ball release speed and between kinematic variables and ball release speed were investigated using Pearson's product-moment correlation coefficients (r). A significant relationship was found between the horizontal velocity during the pre-delivery stride (r = 0.728, P < 0.05) and ball release speed (31.5 +/- 1.9 m(-1) s(-1)). We believe that the high correlation was due to the bowlers using techniques that allowed them to contribute more of the horizontal velocity created during the run-up to ball release speed. We also found that the angular velocity (40.6 +/- 3.4 rad x s(-1)) of the right humerus had a low correlation (r = 0.358, P > 0.05) with ball release speed. Although the action of the wrist was not analysed because of an inadequate frame rate, we found high correlations between ball release speed and shoulder-wrist length (661 +/- 31 mm; r = 0.626, P < 0.05) and ball release speed and total arm length (860 +/- 36 mm; r = 0.583, P < 0.05). We conclude that the variance in release speed within this group may be accounted for by the difference in radial length between the axis of rotation at the glenohumeral joint and the release point.
Here is another simple point of physics: The longer the lever the more acceleration is possible. This is why tall bowlers have a natural advantage as this study proves. However, the Law still applies to you no matter how long your arms are. Both your bowling and non bowling arms are important levers. This means keeping your arms fully extended as you bowl. Most bowlers do this already with the bowling arm, but it's also vital to use the non bowling arm to drive out and down. This allows you to fully rotate your shoulders and move into the follow through: A giant cartwheel whipping through. As this study shows, shoulder rotation is directly linked to speed. It's all about using every inch of the levers you have.
I'd consider that tested!
LeonieKelly18
  • every phoenix needs ashes to rise from
« Reply #24 on: March 12, 2013, 11:06:15 AM »
first of all number 4.. BOYAAAHH!! good come back!
now back to the bowling.
things ive noticed might have already been said:  (abit difficult with this angle)
when you bowl a wider ball you dont finish your follow through.
your front arm needs to be higher and dont just drag it down pul it down for it to be usefull.
stand up straighter.
your timing seems a bit of (only a slight bit)
but it doenst look bad at all!!
ohw and the guy hitting balls to the keeper.. is seriously dangerous  doesnt look like he cares either
Now an ex Dutch international due to injury.
@leoniekelly
« Reply #25 on: March 12, 2013, 11:14:46 AM »
Hey Chad, have watched this video many times now and I can't quiet explain it but there is something about your arms when you run in...almost like they are pumping up/down instead of back and forward...don't know if it makes a difference but doesn't seem right...although I am no one to point anything based on how messed up my action is  :-[...
Another thing is when you deliver you are almost floating the ball, I know you are trying to bowl up to get swing, but if you shift focus a little bit to line and length (just short of good length) you will beat the outside edge a lot more i think...
I could be totally wrong here as I had to force myself to look at the actions because I usually end up following the ball as soon as you deliver...
Kez
« Reply #26 on: March 12, 2013, 12:38:51 PM »
Source
Abstract
Right... study on bowling anthropometric measures, but can you highlight standing tall as a measure? so I would say UNTESTED. I see no mention of "standing tall" or "release height"
Yes a tall bowler has longer arms therefore uses a longer lever which means they can bowl quicker for less work done.
kesoncricket.com
« Reply #27 on: March 13, 2013, 05:13:15 PM »
Thanks for the advice guys, most concerned about the comments on the timing and me not standing up straight enough! Shall be working on these things and I'll upload a new video when some progress has been made! 8)
Unless we are reading completely different huge books written by Bob Woolmer, I'm pretty sure he said that mixed actions must be coached out ruthlessly! :-[
Kez
« Reply #28 on: March 13, 2013, 05:21:57 PM »
agree there chad, think Fez meant neutral action not mixed- which Woolmer does talk about.
kesoncricket.com
