Author Topic: Something Different  (Read 2118 times)
johnnyw
Something Different
« on: April 09, 2013, 04:37:45 PM »
Got this performance laminate made up for me. The bat maker has used a special coating on the back and edges to hide the seam in the laminate. I think it looks very good and will look great once I apply stickers. The bat itself is around 3lbs I say but I need to weigh it as I have no scales at the moment. It is a huge piece of wood with a lovely oval handle. I will probably use it in nets to improve timing otherwise I will sell it on
Cys1
Re: Something Different
« Reply #1 on: April 09, 2013, 05:24:47 PM »
That is indeed something different! That coating does its job, can't see any joint?
Is this a Lam with the very thin laminated layer, hence the performance tag?
johnnyw
« Reply #2 on: April 09, 2013, 08:31:12 PM »
It is a thin laminate on the bat so its for performance rather than edge size
Do people think than coating the bats to cover the seams is the way forward or would they rather the bat the normal way?
Cys1
« Reply #3 on: April 09, 2013, 08:35:39 PM »
I think that coating the with a glossy finish looks a bit unnatural and will draw some attention in any case. Maybe a matte finish would be better.
I presume this is Indian made? Didn't think that they did the performance lams as well.
MD2812
  • Hi, I'm Joe
« Reply #4 on: April 09, 2013, 08:38:18 PM »
To play devils advocate.
Is the coating to hide that it's a laminate, so that it could be used in a league game without the other team knowing better?
johnnyw
« Reply #5 on: April 09, 2013, 08:45:07 PM »
It is not as glossy as it looks in person. The light reflecting off it in the photos. It is Indian made, I got it made as a one off by my bat maker. I will probably get a few more made in the near future
The coating is there for 2 reasons. One is to hide the join and the other is to allow an ugly cleft to be used on the back. The coating might also have a increased affect on the performane, who knows
Cys1
« Reply #6 on: April 09, 2013, 08:54:03 PM »
Would be interesting to know if the coating actually impacts on performance?
Also, wonder how much weight it adds to the bat? Think you should have one made without the coating and test both for performance and see!
Also, did you request a 3lb bat or can he only make them in higher weights?
Colesy
« Reply #7 on: April 09, 2013, 08:58:49 PM »
Looks aside, what's the point in a 3lb lam? If you middle it with a normal 3lb bat it should go like a tramp on chips anyway
johnnyw
« Reply #8 on: April 09, 2013, 09:42:56 PM »
I will look into this and get a few made to compare.
I can get lighter ones made. This was just an experiment as ive never had a lam before and have wantes to try out a heavy bat to improve bat speed
csnew
« Reply #9 on: April 09, 2013, 09:50:00 PM »
how big are the edges?
Sam
« Reply #10 on: April 09, 2013, 10:12:23 PM »
But the general thought its they improve the performance slightly even more anyway isn't it?
Colesy
« Reply #11 on: April 09, 2013, 10:55:31 PM »
I get the concept behind laminates, just don't think at our level they have an effect.
johnnyw
« Reply #12 on: April 11, 2013, 08:58:13 AM »
johnnyw
« Reply #13 on: May 12, 2013, 02:45:27 PM »
Just a quick update on this bat. I have not used it yet because I have only been to cricket once so far this year due to work etc. I also weighed it and was surprised that it is 3lbs 8oz so the pick up is brillient as I have picked up 3lb bats which picked up heavier. I will probably sell this now as I will not get a chance to use such a good bat. The ball nearly hits the roof when I bounce a ball on it
« Last Edit: May 12, 2013, 02:53:53 PM by johnnyw »
