Author Topic: Need tips on handle replacement  (Read 1373 times)
i12breakfree
« on: April 21, 2013, 08:21:56 PM »
One of my friends bat's handle shaking from middle. The splice and the V area is fine and perfect
I have to remove the grip/twine to check but if I got to put a new handle what needs to be done
How to remove the old handle
Cut from the splice using a professional cutter
or ??
i12breakfree
Re: Need tips on handle replacement
« Reply #1 on: April 21, 2013, 08:57:09 PM »
here's the damage pic
i12breakfree
« Reply #2 on: April 22, 2013, 11:22:11 AM »
Any suggestions here?
« Reply #3 on: April 22, 2013, 11:38:21 AM »
I did my CA back in the day, trying to find pics/topic...
« Reply #4 on: April 22, 2013, 11:44:23 AM »
Can't find it but basically got a mate to help me (he is decent with this kind of stuff)...
Cut out he handle using a saw (we used a circular saw which wasn't ideal but it did the job)
Put in the new handle, take it out and plane if need be so it fits well (make sure you are not forcing the handle too much or you will split the bat)...once you are sure about the fit apply good amount of glue and fit the handle...
give her 24 odd hours to dry...once dry I just used a handle plane to make the handle flush with the back and front...didn't use twine but hockey tape instead and it was fine...
i12breakfree
« Reply #5 on: April 22, 2013, 12:01:10 PM »
Thanks tushar
My next door neighbor is in construction
Would get some help with cutting
Hopefully we don't cut it too much
« Reply #6 on: April 22, 2013, 12:23:08 PM »
Thanks tushar
Cool, just cut along the splice line...also make sure you use a good blade as the blade on the circular saw as all black trying to cut the cane handle/rubber inserts etc...
