Author Topic: Oiling question  (Read 1597 times)
shill
Oiling question
« on: May 03, 2013, 03:35:04 PM »
Recently bought a new bat and so began the prep for the season.
After applying a coat of oil the next day I noticed the darker wood(may be heartwood) still had oil on the surface whereas there was none in the lighter side.
Is this common and does it mean I should apply a different approach when oiling?
Thanks!
Re: Oiling question
« Reply #1 on: May 03, 2013, 03:36:17 PM »
It sometimes takes longer to soak into heartwood. Leave it another day or so.
Re: Oiling question
« Reply #2 on: May 03, 2013, 03:45:22 PM »
What he said. Although I don't know why that is, seeing as heartwood is meant to have less sap and is more brittle, so surely the moisture content is lower, so the oil should seep in a little more readily... Strange that...
SkipperJ
Re: Oiling question
« Reply #3 on: May 03, 2013, 03:45:41 PM »
Very common, heartwood (dark) can take much longer to absorb oil. I usually oil the heartwood lightly compared to the sapwood.
CBF gave me BAD real bad!
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Oiling question
« Reply #4 on: May 03, 2013, 03:48:35 PM »
I may be wrong, but I believe heartwood has a higher concentration of Lignin, which is a natural water/weatherproof substance  (Of course, it was a while ago I did A-level biology, so I could be totally wrong)  Because of this, the oil won't soak in as well into heartwood.
Re: Oiling question
« Reply #5 on: May 03, 2013, 03:54:03 PM »
Ah right, that does make sense in that case. What I don't understand though - surely the tree would want the outside to be more weatherproof? I guess the centre of the tree needs to have the most protection though!
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Oiling question
« Reply #6 on: May 03, 2013, 03:56:35 PM »
I think as the tree gets older, the band of lignin moves further to the edge.  Again, don't quote me on this, as I left school about 7 years ago!
shill
Re: Oiling question
« Reply #7 on: May 03, 2013, 09:28:01 PM »
Ah I see thanks for the help
