Author Topic: I thought I had seen it all...  (Read 2030 times)
Manormanic
« on: June 04, 2013, 10:46:35 AM »
...but it turns out I haven't after all.
Sunday one of my teammates asked me to fix a bat for him.  The bat has a large chunk cracked away from the toe - however, the chunk, which is still attached, is rigidly seperated and will not push back to be glued into place.  Thoughts?
Apologies for the lack of photo - one will follow if and when I get chance.
Re: I thought I had seen it all...
« Reply #1 on: June 04, 2013, 10:58:02 AM »
use a bat mallet to knock it back into place and then glue?
« Reply #2 on: June 04, 2013, 02:26:55 PM »
cut it out and insert a new piece of wood - assuming it's a small crack. Photo's would definitely help.
Simmy
« Reply #3 on: June 10, 2013, 03:03:52 PM »
sure it can be fixed.
ryan fixed a lads bat other day half the toe was in two parts bit of glue and a few dowels and some tape!
Manormanic
« Reply #4 on: June 10, 2013, 03:10:08 PM »
Thanks - it was fixed in the end, thanks to a mate who is training to be a surgeon and a scalpel so thin I couldn't see it - the problem was a small stone stuck way up in the crack!!!
