Helmet Embroidered Patches
Author Topic: Helmet Embroidered Patches  (Read 2329 times)
EaglesCC
« on: June 26, 2013, 09:51:43 AM »
Looking to get a one-off patch made for my helmet. Can anyone on the forum do this? Or recommend someone who would be inexpensive to do just one?
Re: Helmet Embroidered Patches
« Reply #1 on: June 26, 2013, 09:56:35 AM »
I've always just cut up old shirts or caps for this.
Cricket-Box
« Reply #2 on: June 26, 2013, 10:01:48 AM »
To produce any embroidered image you need a DST file which can cost between £25 and £75 depending on the complexity of the badge and the number of stitches. Once you have the DST file this can be used to embroider the image/crest/badge on to any garment that can be embroidered. This is why 1-off badges for helmets aren't commercially viable.
The cost of an embroidered badge is typically between £3 and £5 depending again on the number of stitches and quantity required.
DST files have to be digitised by a professional company
« Last Edit: June 26, 2013, 11:53:15 AM by Buzz »
EaglesCC
« Reply #3 on: June 28, 2013, 12:38:54 PM »
Thanks for the replies guys.
Has no idea a one off would be THAT expensive but understand why. May revert to chopping up an old shirt at the end of the season.
dancardiff
« Reply #4 on: June 30, 2013, 03:40:05 PM »
I think there is a company online that does stickers for plastic and fabric helmets, i will try and find a link for you
EaglesCC
« Reply #5 on: June 30, 2013, 03:40:55 PM »
That would be spot on!
dancardiff
« Reply #6 on: June 30, 2013, 04:10:30 PM »
I remember seeing this, I haven't tried it myself but I guess the stickers would stick ok, this is what the guy said
I had some stickers made up for plastic helmets for my club in February and used a company called Diginate, based in South London.  You can specify the shape, size, etc and do it all online.  The only thing you need is a high quality image file of your club badge.
It's a bit of a fiddle to design the badge online, in the end I just sent them the file and some instructions on what I wanted and it was all good.
I had only six stickers made up as a trial run, on square cut clear vinyl 50x60mm and they have been superb.  There is no minimum quantity and for the six I paid only �8 including postage.
EaglesCC
« Reply #7 on: July 01, 2013, 09:34:01 AM »
That sounds like incredibly good value and worth a go. I have seen ‘transfer’ type stickers on fabric wrapped helmets but I suspect those will crack over time.
Had a quick look on the website so will give it a go.
EaglesCC
« Reply #8 on: July 02, 2013, 02:46:32 PM »
Quick update - I contacted Diginate and got a fairly prompt reply suggested they could send me some existing samples to try as they're not sure which type would work best (if any).
Will update in due course.
