Keeping still
Author Topic: Keeping still  (Read 1820 times)
steiner
Keeping still
« on: July 11, 2013, 03:49:20 PM »
This is going to seem an obvious question, so apologies to those who will be tutting away.
I read a lot about the importance of keeping still when batting. My question is what specifically is keeping still and when should it apply?
Are we talking simply head or body? Is it once the ball is released or at the point of impact? How does footwork fit into this?
Thanks in advance!
ajmw89
  • 4XI ornament
    • Wright Cricket
Re: Keeping still
« Reply #1 on: July 11, 2013, 03:53:49 PM »
Keep your head still and your eyes level as the ball is released.  It gives you the best chance of tracking the ball and hitting it properly then.
steiner
Re: Keeping still
« Reply #2 on: July 11, 2013, 03:56:28 PM »
So keeping still is specifically keeping ones head still on impact?
joeljonno
Re: Keeping still
« Reply #3 on: July 11, 2013, 04:11:22 PM »
Keep your head still on release.  You will have the best chance of picking line and length.
Twitter - @joeljonno
stevat
Re: Keeping still
« Reply #4 on: July 11, 2013, 05:23:06 PM »
No, as the bowler releases the ball you should be motionless.  Naturally the first thing you process is line and length, then you move your head into position and so your body and then hands follow.  Sounds simple, isn't always easy and it's very very easy to let errant thoughts enter your head and suddenly you've not tracked one right and you're out second ball as an opener so have to watch everyone else bat then stand for several hours in the field in overcast, cold conditions hating yourself.
Re: Keeping still
« Reply #5 on: July 11, 2013, 09:32:31 PM »
keeping still mainly refers to your head and eyes.
My advice is to say stay still through the bowlers coil and through the point of delivery.
if you have a pre release movement it should be complete as the bowler enters the coil so you are able to stay still with your eyes are level.
does that help.
Re: Keeping still
« Reply #6 on: July 11, 2013, 09:41:23 PM »
does that help.
Agree with this, there was a guy batting in the nets the other day, and seems to be struggling with his batting at the moment, and is doing everything to try fix it. He had a trigger, which he started off standing tall with his knees slightly bent, then went into a crouched position, and saw that he seemed to lose the length of the ball, and as a result can often be playing the wrong length. His head was moving from high to half a head lower, which I feel can throw off the line or length you read. :-[
tate035
Re: Keeping still
« Reply #7 on: July 15, 2013, 10:10:07 AM »
Agree with Buzz :)
I would also add that when your looking to go big or play an attacking shot then you must also keep your head still at point of contact. All to often junior's and lower order batsman lift their head just before contact and wonder why they end up getting bowled or skying the shot. >:(
Re: Keeping still
« Reply #8 on: September 12, 2013, 08:29:38 PM »
Neil D'Costa, known for the years
he has spent coaching Michael
Clarke as well as for his work with
Phil Hughes and Mitchell Starc,
gave a barbed little interview to the
Sydney Morning Herald recently,
pointing out various "fundamental
flaws" in the "non-negotiable
basics" of Australia's top order.
Such is the depth of Australia's
trauma, another filleting with the
knives of the press barely
registered, although D'Costa had a
few hurtful zingers in his
armoury. Yet this was a piece that
could be read another way, too,
because it was a story that said
something about modern coaching.
We are about to enter the second
age of the coach. The professional
game is reaching an apex of
analysis as science reveals more of
the physical realities of batting and
bowling. It's not quite golf – yet –
but it will be one day. As players
become highly priced freelance
contractors, why wouldn't they
employ a personal coach to micro-
manage each aspect of their game?
And why would those coaches not
become high-earning mini-celebs
in their own right? Golf after all
has its swing gurus and its putting
specialists, its mind-managers and
its conditioning champions.
As in golf, a new language is
developing to describe function
and form, a mix between
management-speak and pop-
science. D'Costa's piece is studded
with it: he talks about "kinetic
flow" and the "entry and exit
points" of various shots. Yet at
heart, this new language is another
way of analysing principals that are
as old as the game.
D'Costa offers this jargon-heavy
paragraph on David Warner:
"Warner has what in swing
mechanics is called a reverse
swing. His weight is distributed as
if he's a right-handed batsman
facing the wicketkeeper. The
shoulder facing the bowler is high
when, in fact, it should be lower at
the time the ball is released. That
would enable Warner to enter his
shots with the correct weight shift
and put his nose over the little toe
on his front foot. What I see is
Warner's leaning back. That allows
him to cut easily but, when he
comes forward, his balance is off.
Having too much weight leaning
back also makes him susceptible to
lbw when the ball is swinging."
Or as my taciturn former coach Jim
Cameron would say: "lean into the
ball" (or "lean into the (No Swearing Please) ball"
– he was Australian) .
D'Costa on Shane Watson: "Watson
has a similar shoulder angle and
alignment problem to Warner. He
shifts his weight back when he sets
up. Watson is a big build, so it's
worth comparing him to Kevin
Pietersen or Jacques Kallis, who
each get their front shoulders
down and stand slightly open at
release so they can lean into the
ball, chin-forward."
Or, get your head over the the ball.
On Brad Haddin: "You cannot
recalibrate your judgment if you
move your head and Haddin moves
his head around, both when he's
batting and wicketkeeping. Like
Khawaja, he drops head when
batting and keeping, losing
milliseconds of vision."
Keep your head still.
On Usman Khawaja: 'He breaks
rule No1 – keep your head still.
He's tracking the ball by dropping
his head. After his dismissal in the
second innings of the fourth Test,
Nasser Hussain asked 'How did he
miss that?' The answer is, he
dropped his head before the ball
arrived and was looking at the
ground instead of the ball. Until he
changes that habit and is able to
track the ball in and out with his
head still, the rest doesn't matter.'
Watch the ball.
We're at a juncture, as the late Bob
Woolmer pointed out in the title of
his magesterial book, of the Art
and Science of Cricket. The
fundamental principals of the game
have been known to every player
since the age of Grace. Science is,
at the moment, engaged in
explaining why the art works. It
has value, and as the demands of
its formats drive further, richer
evolution of its methods, it will
have a widening area of study.
But the odest lessons should
always be learned first, and they
don't need decorating. Watch the
ball. Keep your head still. Hit it
when it's under your nose. The
song remains the same.
thank you to jon hotton for these wise words
