Author Topic: Can it be repaired?  (Read 4972 times)
RossViper
  • What noise does a cow make?
    • My Excel Blog!
Re: Can it be repaired?
« Reply #15 on: December 06, 2013, 07:48:10 PM »
Right, after several months sitting in M&H I finally remembered about this bat and asked if they could ship it back. It's arrived back today. Going to have a crack at fixing this. Its too good a bat not. Honestly the performance on this bat is insane, I just hope it turns out ok!
Fair play, drop me a note if you want any advice - is it your first time fixing a bat - its not a straight forward repair!
scottish_slogger95
« Reply #16 on: December 06, 2013, 10:24:07 PM »
Thanks for that, It's not the first time I have fixed a bat but I have to say its the most advanced repair I have done to date. I am just going to get a mitre saw a take of the remaining wood at the side of the bat, then cut a bit of wood of an old bat which will be the same length. Then simply glue, clamp and bind it of with either bits of an old grip or parcel tape. Hopefully that will work. Fingers crossed
Feel free to pitch in any ideas or if you would have done it a different way mate. I appreciate the support
« Reply #17 on: December 06, 2013, 10:32:19 PM »
If it was me I'd wack a dowel or two in there too for added strength
scottish_slogger95
« Reply #18 on: December 06, 2013, 10:35:18 PM »
How would you add a dowel in mate?
« Reply #19 on: December 06, 2013, 10:38:58 PM »
When you've glued it and it's set, drill through so the dowel will go through the repair and into the blade. Put glue on the dowel and in the hole (which doubles up as lubricant)
Tap the dowel in, wipe off excess glue and wait to dry. When dry cut and sand the dowel level with the edge.
scottish_slogger95
« Reply #20 on: December 06, 2013, 10:45:04 PM »
Cheers Cam, How far in should I drill the hole? Should I add two dowels in?
Also were would be the best place to get dowels from?
« Reply #21 on: December 06, 2013, 10:53:59 PM »
I'd go as far as I could into the original blade without going through the other edge personally, but I'm sure someone more experienced than me would give better advice (they might even agree with me, you never know!)
And I got mine from B&Q mate, most shops like that should have some. I think it's best to go and buy it rather than order online so you can judge if it's thickness vs the bat
scottish_slogger95
« Reply #22 on: December 06, 2013, 10:57:28 PM »
Yeah I wouldn't have thought to go right through either, but who knows. I'l message someone on here about it..
yeah b&q's a good shout. I'm very fortunate there is one 2mins away from my house!
RossViper
    • My Excel Blog!
« Reply #23 on: December 07, 2013, 12:46:10 AM »
I don't think taping up, or using old grips is going to do the job for this one to be honest, I would really try and clamp it in a vice or with g clamps at least.
I would dowel it too, you only need to go about an inch or so past the line of the joint to suppot it, but going further probably won't hurt.
Glue the flap down first, using grips will be fine for that bit.
Then cut it all square, then cut the replacement bits, I would use 2 bits looking at it, better a bit on the big side than too smal, then glue them in, claping them across the bat - edge to edge I mean, the shape down roughly, then dowel, then sand to finish!
