Author Topic: Getting out to spinners  (Read 1275 times)
mini998
« on: July 15, 2013, 08:27:33 AM »
I have real difficulty scoring runs against spinners , I can stay in the crease by blocking them and playing in the 'V' but as soon as I start closing the face to score runs on the leg side I get top edges or get LBW .
This happens mostly when a bowler bowls all his balls at stumps , I get frustrated when I block couple of overs.I open the innings and I hate when opposition take the old ball and start with a spinner. Plus we don't have good  spinners in our team to practice against .In nets our spinners bowl all over the place, but in matches opposition spinners bowl pretty much everything at wickets.
Any tips I can practice to overcome this issue?
tate035
Re: Getting out to spinners
« Reply #1 on: July 15, 2013, 10:03:17 AM »
What guard do you take?
If it's middle then perhaps you are planting your front foot to soon and having to play around your pad.
I often see juniors plant their front foot down the middle stump before the ball has even pitched therefore limiting their ability to play leg side.
mini998
« Reply #2 on: July 15, 2013, 10:15:22 AM »
Recently I started taking middle stump and batted with a slightly open stance . I get cramped up balls on the leg stump, I thought having an open stand might help. That works well with fast bowlers , I have little bit of extra room to play shots on leg side now.
Manormanic
« Reply #3 on: July 15, 2013, 10:19:35 AM »
You probably get leading edges rather than top edges.
A good drill to practice is to set up some cones around the wicket - put two of the same colour about five yards apart in three or four places you might look to score.  Then get a mate to give you throw down on the line of off stump, calling out in turn the area into which you are trying to hit each ball.  To mimic the effects of a spinner, get the mate to collapse his wrist and flick the odd ball, not warning you in advance which one will bite.
When you come to bat, make sure you look at the gaps between fielders and think about where you might be able to rotate the strike effectively.  Look on both sides of the wicket - it is oddly sometime safer to play an off spinner against the spin into the region either side of point than it is to work them with them spin through midwicket.
« Reply #4 on: July 15, 2013, 10:30:20 AM »
footwork.
If you play in the V well then why not get down the pitch and look to hit straight. You will rule out LBW in most cases by taking a stride down the track. Maybe going over the top or simply aim for wide mid off/on. Go with your strengths.
Some of us aren't great at nurdling through square leg and while you can improve it's not an overnight fix.
« Last Edit: July 15, 2013, 10:31:52 AM by uknsaunders »
tate035
« Reply #5 on: July 15, 2013, 10:33:52 AM »
A drill that worked for my son who did a similar thing to you was to when in the nets draw a line on leg stump going down the wicket for about 3 metres. Try then when batting to any straight or leg side deliveries get your foot to be on that line. This helps you play more shots with an open face as your not having to play around your front foot.
It takes a lot of practice and try just throw downs 1st before having someone bowl at you.
Banksy
« Reply #6 on: July 15, 2013, 10:36:55 AM »
Im terrible at playing spinners too, and have pretty much the same issues as you!
I'm used to bat with just my back foot in the crease and stay on middle stump, what I've ended up doing is to bat right in my crease, as close to the stumps as I dare and take leg stump guard. Although I run the risk of hitting my own wickets, I find it much more comfortable to push through the covers or chip it over mid-off for an easy one.
