Author Topic: THE EAGLE HAS LANDED  (Read 9239 times)
Vic Nicholas
« on: July 16, 2013, 10:08:59 AM »
My Stretton Fox thigh pad set have arrived!
They look superb and I can say hand on heart that Georgey Fox is one of the coolest cats to deal with.
I will put up a review shortly, but make no mistake, on looks alone, they are a winner!
countycricketplayer
Re: THE EAGLE HAS LANDED
« Reply #1 on: July 16, 2013, 07:38:34 PM »
im sure we are all waiting for some pictures
Vic Nicholas
« Reply #2 on: July 25, 2013, 03:18:08 PM »
Here they are!
Magnificent!
Vic Nicholas
« Reply #3 on: July 25, 2013, 03:23:52 PM »
They do everything everyone has already told you they do.
You can whack away with a mallet, and you will be fine. So if you did happen to face someone that is 90mph+, you have nothing to worry about.
From a design perspective, the main thigh pad is rather big.
While playing normal straight shots, it does not represent any problem.
When playing the hook and especially sweeps, it is somewhat awkward.
If I could design my self a custom set, I would make the top quarter of the thigh pad a separate part connected by the material, so there is a joint that moves when I raise my left leg for a hook, or when I go down on one knee to sweep.
Even so, the thigh pads are seriously fantastic!
Any questions, fire away!
« Reply #4 on: July 25, 2013, 03:34:08 PM »
I have heard that the quality of these pads are absolute top notch. Plus is you have the bespoke service, you can have colours or designs to your liking.
So with that in mind, you said that you would change the shape or make the top quarter like a joint. But would you have added any actual design or graphics to the pads?
Vic Nicholas
« Reply #5 on: July 25, 2013, 03:55:07 PM »
Graphics wise, I like the simplistic look that I have ended up with. My name on them is only a safe guard to avoid them being knocked off more than anything else!
I am 5'11" tall (no shrimp), but I have the rather Celtic trait of a long trunk and slightly shortish legs. So what I mentioned above probably would not be an issue for most of you lads.
As it stands, it doesn't REALLY impinge on my stroke play...but rather would be the final perfect custom fit for me that if I were a test player, I would have sat down with George to customize it for me in such a way.
However, I must stress, that they are far and away the best thigh pads I have ever owned.
What Morrant did for superlite pads back in the 70's is what Stretton Fox have done for thigh pads in the 21st century. It is a technological advancement that people will point to in years to come as the catalyst to a new age of cricket body protection.
I rate it THAT highly.
Once again, I thank George Fox for his patience and help in creating this brilliant thigh pad set.
stevat
« Reply #6 on: July 25, 2013, 04:36:19 PM »
I also have that trait, just under six foot tall but have to buy short man trousers, and have struggled with thigh pads for years.  Generally found my best option is something like the compression shorts to hold it all in place.  Heard that a few people have done such a thing over their Foxes, how did you wear them?
Vic Nicholas
« Reply #7 on: November 30, 2013, 06:43:59 AM »
I have tried them under compression shorts and it feels very tight.
So now I wear them on top of my compressions shorts for a more comfortable fit.
The BIGGEST problem I have been having with my SF's is the inner thigh pad creeping round to the back of my leg during my innings.
I have tried wearing them under compression shorts = no good, it creeps.
I have tried wearing them on top of my compression shorts = still no good, still creeps around behind my leg.
With all-in-one designs this doesn't happen because they are in a set position and cannot go anywhere.
So, if anyone has ever had a similar problem - can you be so kind as to give me some tips to avoid this re-occurring....because it is getting to the point where I feel like dispensing with the inner thigh pad all together.
Fire away guys!
toenails97
« Reply #8 on: November 30, 2013, 09:04:11 AM »
I had a problem with the normal white straps as the thigh pads would slip down, so I asked George for some bespoke towelled ones and they are much better! Keep the thigh pads in place as they're much more heavy duty then the white ones and aren't as thin or flexible! Ask him for some they'll work a treat!
« Reply #9 on: November 30, 2013, 09:49:05 AM »
Fire away guys!
Sounds like you may need to bend them more aggressively to achieve a better fit.
As a rule, it is almost impossible to damage them when adjusting them. I had mine bent double over a steel barrier with all my weight going through the guard, they flexed into the shape i wanted eventually but it can be a lot of hard work. Worth it in the end though.
johnrockin
« Reply #10 on: November 30, 2013, 10:18:08 AM »
Totally agree with this comment. I wasn't impressed with the fit of mine until I put some hard work into bending it. I remember watching a video - on here - were someone demonstrated how much you can bend them with no ill effect. Before I bat, I kneel on the centre of mine and bend it the 'wrong way', then I put it on and let it naturally reform around my leg. For me it provides a ready good fit.
Hope this helps
Vic Nicholas
« Reply #11 on: November 30, 2013, 11:27:29 AM »
I have the heavy duty towel straps as well - but it still doesn't stop the creep!
Vic Nicholas
« Reply #12 on: November 30, 2013, 11:29:36 AM »
Hope this helps
The main thigh pad stays pretty much in place.
No problems there.
The inner thigh pad has a mind of it's own though!
Would really like it to stay in place though!
« Reply #13 on: November 30, 2013, 12:01:13 PM »
I hadn't thought to try that with mine, cheers buddy
toenails97
« Reply #14 on: November 30, 2013, 12:13:15 PM »
No problem Cameron! It's just the white ones are thin and to elasticky in my opinion to keep them in place!
