Author Topic: Finishing Grade Sandpaper?  (Read 2927 times)
Banksy
« on: August 07, 2013, 02:00:29 PM »
Pretty much as the title. I've 300 grit for the drum sander but do I need to go down another level for the final bit of hand sanding? I got some 'ultra fine' foam sanding blocks and they buff the bats up a treat, god knows what grade they are though...
craigwm
Re: Finishing Grade Sandpaper?
« Reply #1 on: August 07, 2013, 02:50:26 PM »
I work through about 6 grades ending up on about 2000 grit. Don't know if there's much point going that low but it produces a beautiful smooth and shiny finish.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #2 on: August 07, 2013, 03:06:04 PM »
I go up to about 800 grit.  Used to go to 1200, but felt that it was overkill.
Banksy
« Reply #3 on: August 07, 2013, 07:14:33 PM »
Cheers.
I've got 120, 240 and 300 on the sander, so might get some 400 & 500 for hand sanding then.
Or do you think I should go another grade on the drum sander, say 400, and finish with 600 & 800 by hand?
« Last Edit: August 07, 2013, 07:18:42 PM by Banksy »
Blazer
  • Team Anti - Concave !.
« Reply #4 on: August 07, 2013, 07:26:10 PM »
There is not a huge difference in finish above 600 especially if you are planning to use wax to buff it up.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #5 on: August 09, 2013, 11:02:57 AM »
Cheers.
I have a black and decker Orbital sander, and go 40, 80, 120, 180, 240, 320, 400 and sometimes 600 and 800, depending on how the bat looks/feels
« Reply #6 on: August 09, 2013, 05:12:29 PM »
40? Wow that's low. I'm not sure about anyone else but the lowest I go is around 120-150. End up around 500. As long as you take your time on each one you shouldn't need to go to low or too high
Fezballoh
« Reply #7 on: August 10, 2013, 04:59:56 PM »
A mate of mine is a veneerer and he said he didn't see the point in going higher than 320 grit. In his own words you are going "below cellular level". A light wax & buff finish is what you want after that IMO.
DevAussie
« Reply #8 on: August 17, 2013, 08:58:04 AM »
I start with 80 and finish with a 400......as you can see from all the responses it's different for each person as people use different brands/quality of paper and finish differently.....I'd recommend trial and error to see what works for you
Fezballoh
« Reply #9 on: August 20, 2013, 06:02:24 AM »
Oakley 'Between coats' sandpaper is the best paper I have found for hand sanding. Really shifts the wood and doesn't clog too easily and can be tapped out quite easily if you know what I mean. Bit pricey though :s
Ryan
  • Trade Count: (+17)
« Reply #10 on: August 20, 2013, 07:15:54 AM »
It all depends on the quality and type of sandpaper used.
Simmy
« Reply #11 on: August 22, 2013, 09:52:19 AM »
this is very very true!
i had some cheap 600 gritt sand paper that i was finishing bats off when i was referbing stuff..
but the stuff ryan uses gets that sort of finish with 150 grit!
tresco
  • County player Highest score 126*
« Reply #12 on: September 06, 2013, 09:07:45 AM »
I tend to finish of using 'wet & dry' paper seems to get a better finish
can go as far as 1200 grit
http://www.screwfix.com/p/titan-wet-dry-sanding-paper-230-x-280mm-600-grit-pack-of-10/95130
