Impulse buy - guess the weight
Author Topic: Impulse buy - guess the weight  (Read 2967 times)
Jogetnz
« on: August 20, 2013, 08:34:23 AM »
As the story goes this bat was donated by Brendon McCullum to a charity for them to sell. What you see is all I know about the bat, it looks a decent lump of wood to my untrained eye, absolutely no idea what the pickup or performance will be like and I didn't buy it for the signature, that will come off straight away.
What sucked me in was the weight, I will let a few guess then post the answer.
The bat has not arrived yet, I will post more when it does. Paid NZ$350, £175.
Re: Impulse buy - guess the weight
« Reply #1 on: August 20, 2013, 08:35:06 AM »
2'8
Number4
« Reply #2 on: August 20, 2013, 08:39:08 AM »
I'll go 2lb7.5oz
BigBlueMachine
« Reply #3 on: August 20, 2013, 08:39:28 AM »
2'7
« Reply #4 on: August 20, 2013, 08:44:16 AM »
2lb7 or 2lb8
joeljonno
« Reply #5 on: August 20, 2013, 08:50:12 AM »
2'9.5
Twitter - @joeljonno
Jogetnz
« Reply #6 on: August 20, 2013, 08:50:29 AM »
Well guessed by most, 2.7lbs!
EaglesCC
« Reply #7 on: August 20, 2013, 10:01:30 AM »
I don't think I've ever seen a Puma 'Reserve' grade bat before but I have two 6000 (Pro) grade bats in the Bat Stable. Neither has been used yet but the rebound is pretty good on both. I was most impressed with the pick up. Both weigh 2'8 but the Cabolt has a long low middle however picks up like a high middle bat.
Would be interested to hear what you make of the weight to size ratio too. Both mine as pretty big for their weight.
mini998
« Reply #8 on: August 20, 2013, 10:10:54 AM »
I have noticed lot of Pros use bats around 2'7 , but most of club cricketers like us tend to use bats around 2'9-2'10.
patriotscreen
« Reply #9 on: August 21, 2013, 10:08:22 AM »
Most likely because we dont have quick bouncy pitches to play on and our reaction speeds don't need to be as good. Pro players can block deliveries that will still go to the boundary! Therefore you don't need as much weight in a bat because you can use the pace of the ball to your advantage.
Cricklade 2nd XI
Russ
Jogetnz
« Reply #10 on: August 25, 2013, 09:24:29 AM »
Well I now have said bat in hand. I would post more pics but due to an unfortunate combination of bubbly, my cellphone and the restaurants concret floor I don't have a camera at the moment.
Unfortunately the online conversion from grams to pounds caught me out, it weighs 1225grams, which when plugged into the converter returned 2.7lbs, which I read as 2lb 7 ounces which is wrong, it actually weighs 2lbs 11 which if I had realised I would not have bought it. That being said its still a reasonable piece of wood for that weight, it's certainly bigger than my H4L which weighs the same. The bat has 41mm edges and 65mm spine, and a reasonably thick toe at 30mm and has a lot of timber throughout the length of the bat. It has minimal concaving and a slight bow. 11 grains with a touch of heartwood on the inside edge.
The handle is very interesting, it has what I would say is a standard oval at the bottom but then tapers to an extremely thin top of the handle with what appears to be a counterbalance weight taped at the top of the handle, I have not taken the tape off but will do so when I have acess to a camera.
It would appear that he didn't spend too much time breaking it in as it does have a number of seam marks showing, funnily enough 90% of these are right in the middle of the bat up and down the length of the bat, very few on the edge, from how easy this bat leaves seam marks I can say that it actually has had very little use and I suspect has only been used indoors as the toe is clean with a touch of scuffing. It does have a small crack at the toe where it has a depression from a Yorker but this won't be an issues.
It does have a great pickup, feels lighter than my H4L which is a bat I consider picks up well.
Response wise its good, no better than my H4L, I'm going to spend some time with the mallet on it and see if it makes any difference.
03jaworf
« Reply #11 on: August 25, 2013, 09:32:55 AM »
shame about the mix up with the weights but still looks a cracking bat, keep us posted how it performs when played in mate
csnew
« Reply #12 on: August 25, 2013, 10:16:37 AM »
nice review.
Is it full size? heard a few people saying BCM uses a slightly shorter blade due to his height
Jogetnz
« Reply #13 on: August 25, 2013, 10:21:34 AM »
nice review.
Yip, full size.
Vulcan Cricket
« Reply #14 on: August 25, 2013, 10:31:44 AM »
2lb 11oz
