Author Topic: full balls on leg  (Read 1946 times)
Old boy
  • The older I get, the better player I was.
full balls on leg
« on: August 21, 2013, 11:45:44 AM »
Hi all, having some issues with full balls on leg stump, often results in leading edges or inside edges.
 When the ball is a little short I'm not having an pulling nor do I have a problem when the ball is pitched anywhere from outside off to middle, its just front foot shots when on leg stump. Any ideas on what I could try would be appreciated. Thanks
mad_abt_cricket
Re: full balls on leg
« Reply #1 on: August 21, 2013, 11:51:55 AM »
Wait for the ball to come to you instead of putting your leg forward, when the ball is quite full on the leg stump. Approach with a straight bat instead of playing across the line like when you do for a short ball to pull or cut.
Initially target straightish midon / midwicket and once you start to middle the ball, you can try to use your wrists at the last moment for  a flick toward square leg or even fine leg.
« Reply #2 on: August 21, 2013, 12:08:47 PM »
As said above - players find it "easier" to try to whip the ball to behind square, when that actually can be a difficult and high risk shot.
Aiming to punch the ball through mid on is the way to go.
The Palmist
  • Trade Count: (+15)
« Reply #3 on: August 21, 2013, 12:11:34 PM »
very sound advice by mad abt cricket.
I am sure it is mouth watering for many these full balls on leg. You can also try experiment with your guard or stance.
jamesisapayne
« Reply #4 on: August 21, 2013, 12:23:59 PM »
Bob Woolmer's video is good for this shot - he suggests showing the full face of the bat but using the top hand to close the face (just a little) on, or just after contact with the ball. If you're trying to flick it too much you'll close the face early and get a leading edge or miss the ball completely.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #5 on: August 21, 2013, 01:03:21 PM »
Ramp it a la Jos Buttler!
jamesisapayne
« Reply #6 on: August 21, 2013, 01:21:19 PM »
Aldred Cricket Bats
    • Aldred Cricket Bats
« Reply #7 on: August 24, 2013, 07:27:15 AM »
Check your not falling over to the off side as well as you play it. This will force you try and hit squarer thus using half a bat. Try stepping straight through the line of the ball after you've played it. This is a great thing to practice in the nets with the bowling machine or bobble feeds. Good luck
toto schillachi
« Reply #8 on: August 28, 2013, 01:17:54 PM »
I would say ensuring you middle the ball is more important than the exact placement -after all if you do middle it you should pick up runs regardless of how fine you manage to get it.
Simmy
« Reply #9 on: August 28, 2013, 01:23:47 PM »
im shocking of my legs full stop i just trying smash the ball over square or mid wicket...
i cant remember any time in my playin life where i have pushed the ball to mid on diliberatly.
but this is due to me falling over so my balance is off.
RoyalParkReds
« Reply #10 on: September 03, 2013, 02:52:01 PM »
Some good answers so far. For me, balance was/is the issue when playing anything down leg. I found it helped to be more side on with my body. I found I was pointing towards mid off/cover and would naturally fall to the on side.
Nato
  • Back in the saddle...
« Reply #11 on: September 12, 2013, 01:08:12 PM »
Some very sound advice on this thread. I had an issue getting bowled playing this kind of ball this season as I was closing the face and letting the ball through the gap between bat and pad. I concentrated on playing straight and managed to turn a dismissal ball into a run scoring one, including getting a flick off my legs spot on. Might have been more luck than judgement though!
Pontymister 2nd XI
Glamorgan & Monmouthshire Division 3 Champions 2013
