Author Topic: Any Tips on my bowling (NEW VID)  (Read 3294 times)
acko109
« on: September 06, 2013, 03:37:14 PM »
After becoming an off spinner a year and a bit ago after getting my action changed my seam is starting to come back a little bit but im looking for a few tips to help us get back to being able to make the choice on what to bowl in game situations.. Theres a little video of me bowling seam in the nets any tips welcomed as would be nice to get back to bowling it
Cricket nets ... Return of seam bowling
« Last Edit: September 12, 2013, 02:56:16 PM by acko109 »
BigBlueMachine
Re: Any Tips on my bowling
« Reply #1 on: September 07, 2013, 02:32:42 AM »
Best thing about your action is a strong front leg. However did you know you bowl with a mixed action? Back foot lands side on and you look inside your non bowling arm, so front on. Need to get that sorted ASAP not just for performance but also for injury protection. It seems you lean back in your flight phase, when you want everything going towards the target/batsman. When you land your front foot if you were to draw a line front your back foot heel to through your front foot heel the line would be pointing towards fine leg. Again you need this to be pointing at the batsman. What that then makes you do is add lateral force to get around your front leg t be in a squared on positin at relapse. The ideal is knees, hips and shoulders square on to the batsman at release. Evidence of this lateral force is you falling to the off side and your follow through to the off side, again needs to be straight through the crease towards the batsman before tailing off the pitch.
Now initially this seems a lot however I believe if you sort out your feet this will have a knock on effect for the rest of the action.
Does look as though you have a good wrist positin which I suspect makes the delivery look good and get bounce but there is more potential not being realised.
acko109
« Reply #2 on: September 07, 2013, 09:27:17 AM »
I used to bowl a bit quicker than this when i was around 14 -15 but my action got changed by a not very good old club captain so it messed me up.. thats why i stopped originally bowling it .. but ran in at nets the other day n thought id give it a go .. and this is how it come out .. ill keep recording and try and do as you said n see how it comes out ! Cheers for the tips mate
BigBlueMachine
« Reply #3 on: September 07, 2013, 09:37:14 AM »
I would think the fact you have been bowling off spin is a reason for the things I have previously mentioned. With spin you need that rotation around the front leg to get revs on the ball.
Just remember, if you run in straight and everything going through the crease is straight and towards the batsman then the ball will come out straight. And contrary to belief the better your action is for accuracy the better it is also for pace.
To sort your feet out you might need to build it up from a standing start to walk through to a couple of paces and every time you increase make sure your action remains good.
« Reply #4 on: September 07, 2013, 10:21:28 AM »
Looks decent.
Number4
« Reply #5 on: September 07, 2013, 10:56:18 AM »
Need to keep your hips straighter at release and push through to your target instead of running off to the left
« Reply #6 on: September 07, 2013, 07:14:04 PM »
I think it's a dangerous thing to be stuck between knowing if you are a spinner or a seamer.
acko109
« Reply #7 on: September 07, 2013, 07:38:01 PM »
well im an off spinner but its a case of if were stuck i can do either .. i used to be an out and out seamer but when my action got changed i lost all pace and accuracy which is why i took on spin.. ill get some vids up over the week n see how its going !
« Reply #8 on: September 07, 2013, 07:41:13 PM »
How many people can do both well? Not many.
acko109
« Reply #9 on: September 07, 2013, 07:49:35 PM »
Good point mate.. but if you can do both you may aswell theres none at the top level but in lower leagues as long as you can put it there or there abouts its ok
compstallcc
  • Colts
« Reply #10 on: September 07, 2013, 08:26:28 PM »
as said i think it would help if your follow through was straight towards the stumps could possibly add an extra yard of pace and wouldnt give your head the chance to slide away to the right
"To me, it doesn't matter how good you are. Sport is all about playing and competing. Whatever you do in cricket and in sport, enjoy it, be positive and try to win." - Ian Botham
acko109
« Reply #11 on: September 07, 2013, 08:29:01 PM »
With regards to this.. should i sort of push my head down ? and carry on straight .. or just run straight down if that makes sense?
BigBlueMachine
« Reply #12 on: September 07, 2013, 08:37:24 PM »
Your follow through should happen as a result of your bowling action. You shouldn't think about actively trying to force yourself towards the batsman. If you get everything sorted before that it should naturally occur. Like I said earlier it will be a case of sorting 1 or 2 things out and it'll have a knock on effect to the rest. When people comment about a follow through its because its an indicator of something not right causing you to go off to the side. No one has ever been a good bowler because of having a good follow through. Concentrate on your action when between the two lines and the rest will come.
acko109
« Reply #13 on: September 07, 2013, 08:40:32 PM »
ok mate.. ill get the camera out in the week n see how its goes.
« Reply #14 on: September 08, 2013, 04:34:24 PM »
Wouldn't you rather invest time and effort in being very good at one or other?
