Author Topic: what are protectoes and though toes lami toes  (Read 2426 times)
nicko95
« on: November 03, 2013, 11:24:41 AM »
can anyone explain what the difference between these are ?
Torque
Torque
Re: what are protectoes and though toes lami toes
« Reply #2 on: November 03, 2013, 11:44:25 AM »
Basically a tuftoe is a toughened fabric wrap to protect the toe and lower edge, and a lamitoe is a hardwood fitting into the toe. The addition of a lamitoe turns the bat into a Grade B bat. This means that it would not be allowed to be used in First Class cricket.
nicko95
« Reply #3 on: November 03, 2013, 11:47:48 AM »
whats the fabric do you know
Torque
« Reply #4 on: November 03, 2013, 11:52:19 AM »
Here's a lamitoe:
Torque
« Reply #5 on: November 03, 2013, 11:53:19 AM »
And this is a Tuftoe:
Torque
« Reply #6 on: November 03, 2013, 11:59:09 AM »
I think it's just cotton tape. The tuftoe is usually applied when there's a crack going through the toe. What happens is the cracks are glued and let to set. The cotton tape is then tightly wrapped around the toe and brushed with glue so is sets solid, almost like a cast. This should help to prevent the crack from opening back up.
Torque
« Reply #7 on: November 03, 2013, 12:03:17 PM »
Another alternative would be to wrap the toe with twine (the same stuff that should be around your bat handle), in a similar process the cracks in the toe are glued and left to set. Instead of applying fabric tape you can apply twine in the same manor, wrapping it tightly and brushing it with glue so it sets solid.
I hope these help, any questions fire away.
Torque
« Reply #8 on: November 03, 2013, 12:09:24 PM »
Here's some photos of the twine process ( I hope you don't mind me pinching these Ryan!)
Torque
« Reply #9 on: November 03, 2013, 12:09:56 PM »
And again:
