Author Topic: Pod Players with TAS inserts  (Read 4723 times)
Wickets-then-runs
Re: Pod Players with TAS inserts
« Reply #1 on: November 04, 2013, 08:37:56 AM »
Is this one of yours, mate? If so, have you noticed any change in the way the bat sounds?
ogroupleader
« Reply #2 on: November 04, 2013, 09:17:27 AM »
It is. I don't have it back yet. Should get it by the end of the week I hope. You can have a hit when we do a net session but it is going to be on the light side. I have another Thruxton coming in which will be closer to your weight. That should be here this week as well. The Argon is due any day. We should def do a net session this week. Especially as I'll be fielding all day on Sat.
simonmay5
« Reply #3 on: November 04, 2013, 10:12:58 AM »
Is this a new line that Salix will use in 2014
ogroupleader
« Reply #4 on: November 04, 2013, 10:44:30 AM »
No its just a Pod Players with the TAs inserts retrofitted. It weighed less than 2lb 6 without the inserts so should be about 2lb 9 now.
TAS Bats
« Reply #5 on: November 16, 2013, 11:23:40 AM »
Looking forward to your feedback Shane!
ogroupleader
« Reply #6 on: November 17, 2013, 09:20:19 AM »
The latest arrivals.
Pod Players with TAS inserts. 2lb 8.34oz. Weight prior to inserts was 2lb 6oz. It will get its first hit out this week.
Thruxton Players 2lb 10.3. Sensational. I have used it in one net session and the ball just flies. Unlike my Thruxton SPS there is no jarring sensation. It just feels sweet. The SPS hammers the ball as well but it feels a little harder than the Players. The SPS is only 2lb 9oz and is much smaller then the Players. Smaller edges and a smaller spine. The SPS is still my match bat though.
Argon Original LE 2lb 9.7oz. This is a big bat. Huge edges. Not much concaving. The handle is very thin which makes the bat feel bigger - like having a toothpick attached to a tree trunk.
patriotscreen
« Reply #7 on: November 19, 2013, 04:55:22 PM »
How much did it cost to get these retrofitted and who did it? Seems like a good way to strengthen the bat and add some weight.
I have a Slazenger V360 that only weighs 2.6 and I like 2.8 so could use these to get the weight up to the required amount.
Cricklade 2nd XI
Russ
compstallcc
  • Colts
« Reply #8 on: November 19, 2013, 06:04:44 PM »
http://www.tasbats.com.au/products.html          85 aud about 50 quid i think? postage to aus would be a killer though
"To me, it doesn't matter how good you are. Sport is all about playing and competing. Whatever you do in cricket and in sport, enjoy it, be positive and try to win." - Ian Botham
ogroupleader
« Reply #9 on: November 20, 2013, 03:11:55 AM »
I paid $110. But I also had the face sanded back as some of the willow had lifted when I removed the extratec. The face of the salix seems very fragile. Even when I put the new extratec on there was some lifting of the willow when I repositioned the extratec. I have never had a bat behave this badly.
« Reply #10 on: November 20, 2013, 08:48:57 AM »
Too dry maybe??
ogroupleader
« Reply #11 on: November 20, 2013, 11:46:23 AM »
I don't know. It had been oiled a few days before applying the extratec so I wouldn't think so. I'll just have to be careful with it.
Gave it a solid workout today. At 2.8 it still feels too light but there is sufficient weight in the bat now to generate some good pace on the ball. The sweetspot feels huge. Chopping and changing between the Salix and Thruxton Players I could really feel the difference. The best way I can describe it is by talking about tennis racquets (an industry where advances in technology are embraced).
The tennis racquets designed for bad players are the ones that are bristling with technology - because these players need all the help they can get. These racquets are designed to have a massive massive sweetspot. The racquet engineers achieve increases in sweetspot size by increasing stability (torsional and recoil). Torque/twist = lost energy therefore an absence of torque/twist = more energy transfer = larger sweetspot.
The downside of a large sweetspot is that you lose feel for the ball. You become isolated from the impact. Without feel you sacrifice control. Which is why racquets designed for good players have relatively small sweetspots.
The Salix with the inserts feels like a racquet that a bad player would use. It is all sweetspot. With the Thruxton you feel more connected to the ball. You can still hammer the ball but when you don't get it just right the bat lets you know about it. When you don't hit it dead centre with the Salix it still feels like a sweetspot impact.
i12breakfree
« Reply #12 on: November 20, 2013, 12:47:01 PM »
So is it a good thing to oil on the edges with TAS or should that be avoided like they say to avoid near the splice area ??
patriotscreen
« Reply #13 on: November 20, 2013, 02:48:06 PM »
Oh bugger. Maybe a better question would be who could do this in the UK?
Cricklade 2nd XI
Russ
smokem
« Reply #14 on: November 20, 2013, 02:59:11 PM »
Pretty sure it's patented so you won't find anyone else doing this legally out in the open...
