Author Topic: Oiling the back of the bat  (Read 1638 times)
ogroupleader
« on: November 18, 2013, 12:54:27 PM »
Does oiling the back of the bat serve any practical purpose or is it just cosmetic?
Krs
Re: Oiling the back of the bat
« Reply #1 on: November 18, 2013, 12:57:03 PM »
Well I do both sides.
I am under the impression that you do the front to prevent moisture leaving the bat......In my head moisture can also leave the bat via the back, so I oil that to.
mdg20
    • Walthamstow CC
« Reply #2 on: November 18, 2013, 01:05:54 PM »
Ive always done a light oli on the back - just to protect it from moisture etc
VKS
    • VKS / Cricket City
« Reply #3 on: November 18, 2013, 11:23:58 PM »
Oiling the back is just as important as the front. Naturally if you have a protective sheet on the face then oiling the back becomes essential.
sgcricket
« Reply #4 on: November 19, 2013, 01:28:25 AM »
Do apply a light coat to the back as well. Will agree with what Krs and VKS have said.
Wickets-then-runs
« Reply #5 on: November 19, 2013, 04:37:30 AM »
I always oil the back of the bat as i sweat a lot when taking guard and it drips onto the bat. As i also hit the ball with the back of the bat a lot, it helps with not splitting and the knocking in process...  :D
mdg20
    • Walthamstow CC
« Reply #6 on: November 19, 2013, 08:21:02 AM »
?? - try holding it the other way round with the flat bit facing the bowler ;) :D
mattw
    • PRYZM Cricket
« Reply #7 on: November 19, 2013, 08:29:12 AM »
In short, yes.
Moisture escapes from everywhere on the bat that is not covered with either a sticker, scuff sheet or tape(where the bat is naked willow). So regularly applying an even small coat of all on the areas that are not covered is basically asking as a barrier to prevent the moisture from the willow escaping.
