New Possible Product / Batting Pad Inserts / Feedback needed !!!
Pages: [1] 2 3 4
Author Topic: New Possible Product / Batting Pad Inserts / Feedback needed !!!  (Read 14344 times)
StrettonFox Sports
  • High End Ballistic Blunt Trauma Shielding
    • Stretton Fox Sports
« on: November 24, 2013, 03:03:29 PM »
Hi Everyone,
Theres been a lot of questions about being able to modify existing equipment.
My questions is how would the sound of "Shin Protector" inserts for existing batting pads / one size fits all be ?
These could simply slide between the cushioning panels in existing pads, cost less than new pads and hope to increase the protection considerably (Imagine your current pads, now imagine also having a layer of Stretton Fox protection over the fragile front shin).
The risk assessment also seems like maybe only one would be needed for the front facing pad so these could sell individually ?
Not sure about price quite yet, but probably looking at about £30ish.
Looking forward to hearing your thoughts, cheers !
George
Stretton Fox Sports
Web: http://www.strettonfoxsports.com
Giraffe208
Re: New Possible Product / Batting Pad Inserts / Feedback needed !!!
« Reply #1 on: November 24, 2013, 03:07:53 PM »
Sounds like a fantastic idea and a reasonable price point too. Would save always shelling out for top tier pads and utilise a cheaper version with added protection inside.
« Reply #2 on: November 24, 2013, 03:12:26 PM »
Like the idea but it not the shin i worry about most it the bit where the shin bolster meets the knee roll that for me is the weak area.
Not convinced with the buying cheaper as people know softs are competitive market as it is unless you buy the very bottom of the range 30 quid is going to negate any potential saving.
Like the idea but you do not see to many shin injury's and most mid range pads have the hard plastozote insert which surfaces
« Last Edit: November 24, 2013, 03:15:15 PM by procricket »
Blazer
  • Team Anti - Concave !.
« Reply #3 on: November 24, 2013, 03:14:52 PM »
Would benefit users of pads that are very light in weight like the Morrant International pads.
« Reply #4 on: November 24, 2013, 03:15:14 PM »
Dr Foxy a few questions to hopefully aid you and development....
How many injuries occur by being hit on the shin of a pad?
Would u be taking away materials to retro fit a SF offering adding the benefit of reduced weight and increased protection?
Is £30 worth it or would you be better off buying a new set of pads as it's more likely the instep/PU/straps will suffer wear and tear before the padding gives up the ghost IMO.
« Reply #5 on: November 24, 2013, 03:31:21 PM »
I have an old set of £20 slaz pads from JJB from my U13 days kicking round, I could dig them out if you need a guinea pig
cheese
« Reply #6 on: November 24, 2013, 04:41:13 PM »
More then happy to test some out over winter nets if you want ;)
« Reply #7 on: November 24, 2013, 04:49:57 PM »
To be honest, if you had SF shin pads, you probably don't need the rest of the pad...
Can't say I know anyone who has ever been injured on the shin due to pads not protecting enough. Even with a bowling machine at 95mph.
StrettonFox Sports
« Reply #8 on: November 24, 2013, 04:53:59 PM »
Sir always a pleasure )
Stretton Fox Sports
StrettonFox Sports
« Reply #9 on: November 24, 2013, 04:58:54 PM »
Hi Everyone thanks so much this feedback is awesome ! I agree with comments that perhaps this is not needed which is why its great to put it out there !
There is a plan for a complete solution further down the line, but the thought is if perhaps something could provide additional support if required ?
TomTek ! In answer to the questions, this could just slip between the inner cushioning sections of the pad, my concern is if users do some "Home improvements" to existing pads by cutting other parts out to save on weight and potentially compromise the overall protection.
Keep the thoughts coming ! all questions appreciated !! :)
Stretton Fox Sports
iand123
« Reply #10 on: November 24, 2013, 05:27:51 PM »
Struggling to see the benefits where as with most pads an extra £30 would just get you the better protection if the pads. I guess these would be portable and you could use on multiple pads.
Not sure if I've missed something but are these only for pads and not like some fielding shinpads which you could use separately to batting?
joeljonno
« Reply #11 on: November 24, 2013, 05:45:05 PM »
I'd be interested, as longevity of this pad would outweight immediate cost.
For instance, I bought some bargain Kook 400s, but could feel the ball through them when the were sharpish.  If I could get these in place, once one pair of pads wear out, I can remove these and put in my new pads, which will also be cheap because I don't need the high range.
Only thing as mentioned about, if you could get something near the knee too, that's be beneficial too.
Twitter - @joeljonno
Number 11
« Reply #12 on: November 24, 2013, 06:45:08 PM »
I think it's a good idea but depends on how they will fit in the pad. Most won't want to start cutting and stitching.
How about a set of guards that cover the shin and knee for close in fielders, like the detachable guards from the M&H pads.
« Reply #13 on: November 24, 2013, 06:48:55 PM »
I guess my thoughts here are that you can pick up to of the line pads in the sales every year for around £50. Whilst these cost £30 I just don't see the market, especially when you consider how long pads really last (not in cbf-land).
StrettonFox Sports
« Reply #14 on: November 24, 2013, 06:57:40 PM »
Awesome feedback !
The brand would only want to bring out something that is genuinely beneficial, I can already make short-leg fielding pads which are being used by a lot of county setups at the moment, and the "Leg-System" although delayed will not be too far away from initial release hopefully. So perhaps this concept of additional protection may be seen as more of an attempt to just make sales which I would not wish to do. Each product that comes out needs to be absolutely unique and either set a new standard or provide a better solution.
Stretton Fox Sports
Pages: [1] 2 3 4
