Sweaty helmet syndrome
Author Topic: Sweaty helmet syndrome  (Read 4714 times)
BigBlueMachine
« on: November 27, 2013, 09:08:16 AM »
I had an issue on the weekend. Now I'm generally on the more sweaty sides of things whilst batting. However on the weekend I got to a stage where I had sweated so much the sweat was dripping from my helmet. I did the press the helmet against forehead trick to squeeze as much out as possible but this was only a temporary solution. I was at a stage where whilst running, sweat was flying out, so much so it was landing on the back of my bat. The only way to deal with this was to get rid of my helmet and turn to the trusty cap. This is not an option I'm too keen on.
Apart from buying multiple helmets and having a backup in case of sweat (like batting gloves) was wondering if there is anything others do or any helpful advice.
FYI I bat in a Masuri Ti helmet.
Re: Sweaty helmet syndrome
« Reply #1 on: November 27, 2013, 09:12:52 AM »
getting hold of some spare swappa bands to interchange once one is saturated is prob ur best option. Relatively cheap compared to buying a new spare helmet.
im sure some of the retailers on here would be able to source them for you.
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #2 on: November 27, 2013, 09:15:36 AM »
Failing that, I find a headband or bandanna under your lid does the trick
« Reply #3 on: November 27, 2013, 09:20:04 AM »
I want a bandana, can anybody recommend one?
BigBlueMachine
« Reply #4 on: November 27, 2013, 09:24:52 AM »
Cheers for the feedback. Don't want to add anything like a headband or bandana as that would affect the fit of my lid. Looking at the swappa bands as I'm in Aus I've found they are sold at Greg Chappell CC.
Presumably this? Bottom right.
http://www.cricketcentre.com.au/helmet-accessories-c-14_248.html
« Reply #5 on: November 27, 2013, 09:28:03 AM »
correct yes, they should be changeable in the helmet then.
We have supplied 3 sets of different thickness of padding with the new PremierTek models so if people do sweat through one at least they have a couple of spares (even if they are a big thinner/thicker than their normal one they use).
« Reply #6 on: November 27, 2013, 09:33:34 AM »
If you wear one I'm dropping you!!!
ajmw89
  • 4XI ornament
    • Wright Cricket
« Reply #7 on: November 27, 2013, 09:51:57 AM »
The ones I use, I tend to pick up at music festivals!
johnrockin
« Reply #8 on: November 27, 2013, 10:20:46 AM »
I'd recommend a Halo II from Halo Headband UK Ltd www.haloheadbanduk.com/product-category/halo-ii-pullover-sweatband
Well priced, not chunky (like a headband) and worked for me last season.
« Reply #9 on: November 27, 2013, 10:23:59 AM »
A more ventilated box helps, oh you're on about a different sweaty helmet syndrome...  :-[
johnrockin
« Reply #10 on: November 27, 2013, 10:27:56 AM »
Thanks for making me smile on a Wednesday :)
RoCo Da Pixie
« Reply #11 on: November 27, 2013, 10:39:03 AM »
Are those halo sweatbands decent under an Ayrtek lid?
« Reply #12 on: November 27, 2013, 10:59:36 AM »
trypewriter
« Reply #13 on: November 27, 2013, 11:00:50 AM »
Loads of them down our way (Croydon) even plain white ones. Cost about £3 for the full head cover ones from memory.
« Reply #14 on: November 27, 2013, 11:04:56 AM »
put bandanna into ebay - you can get them for 99p posted!!
