Author Topic: Bat Refurb  (Read 3776 times)
wcc
Bat Refurb
« on: November 27, 2013, 10:07:13 PM »
Just dug out an old Puma a team mate gave me and was thinking about refurbing it would just like some opinion wether or not it can be saved?
Nice clean grains and still has excellent ping.
Better close up.
Slight surface cracking on the outside edge to be expected.
This is the main problem there seems to be a crack running down both sides of the splice, opinions?
« Last Edit: November 27, 2013, 10:15:02 PM by wcc »
Re: Bat Refurb
« Reply #1 on: November 27, 2013, 10:16:41 PM »
the cracks down the side of the splice make me think it's probably a lost cause (someone better qualified than me might say different)
wcc
Re: Bat Refurb
« Reply #2 on: November 27, 2013, 10:19:01 PM »
Yeah im guessing it would be but just thought i would post, not bad to be given it was free.
Re: Bat Refurb
« Reply #3 on: November 27, 2013, 10:22:09 PM »
If it was me I'd be tempted to dowel through the shoulder and then re-furb it totally.
Given that it's free anything you get from it is a bonus  :)
RossViper
  • What noise does a cow make?
    • My Excel Blog!
Re: Bat Refurb
« Reply #4 on: November 27, 2013, 10:35:36 PM »
what does it feel like now - the handle i mean, should be fixable - but a bit hit and miss with things like that.
wcc
Re: Bat Refurb
« Reply #5 on: November 27, 2013, 10:40:56 PM »
Does have abit of give in the handle, what would be the best way of fixing it? Might aswell give it a shot.
Vulcan Cricket
Re: Bat Refurb
« Reply #6 on: November 27, 2013, 10:58:11 PM »
Hi matt you can  open her up and put a very stong glue in there I had a bat like that years ago glued it up and it was fine
wcc
Re: Bat Refurb
« Reply #7 on: November 27, 2013, 11:02:38 PM »
So just try and get as much glue in the cracks as possible? What type of glue we talking?  :-[
Vulcan Cricket
Re: Bat Refurb
« Reply #8 on: November 27, 2013, 11:11:16 PM »
strong as possible wood glue you can get or grilloa glue best one i found is the stuff you damp the wood then glue the clamp
wcc
Re: Bat Refurb
« Reply #9 on: November 27, 2013, 11:14:51 PM »
Ok mate think i will give that a go over the weekend cheers.
Number 11
Re: Bat Refurb
« Reply #10 on: November 28, 2013, 09:05:17 PM »
I'd be tempted to drill and dowel it where the tape line is, going into the splice at a downward angle.
Ryan
  • Trade Count: (+17)
Re: Bat Refurb
« Reply #11 on: November 28, 2013, 09:23:06 PM »
Best thing to do is remove the hande, glue the crack and bang a new handle in.  You can get in to both sides of the crack so will be stronger.  But if you don't want to go to that trouble it should be fine if you open it up and glue.
SkipperJ
Re: Bat Refurb
« Reply #12 on: December 02, 2013, 10:23:22 PM »
How do you open up a hairline crack like that? Best bet IMHO would be to soak in some superglue and bind the shoulder with twine.
CBF gave me BAD real bad!
Re: Bat Refurb
« Reply #13 on: December 02, 2013, 10:54:51 PM »
No need to open a crack like that up, water down some PVA so it's slightly runnier than usual, place the bat so that the crack is facing up and put the glue on. Gravity will do its thing to get some glue in there.
As far as super glue, doesn't it dry too quickly to be effective?? (And I imagine it's make a right mess of the wood?)
yogi206
  • Part-time Pete
Re: Bat Refurb
« Reply #14 on: December 03, 2013, 11:31:26 AM »
I wouldn't use superglue that seems a bit extreme, I always used pva with the smallest amount of water, best way to open up a small crack it to get a wood wedge and sharpen it right up and tap into the crack. or you could dowel through one side to the other ( have seen some companies do this for toe support go through the splice and out the other side glue the dowel rod and tap it through cut off and sand it to blend in, will have to be a really nice fit to benefit though... but not too snug ;-)
