Author Topic: Is this delamination?  (Read 1401 times)
Shamrock Cricket
« on: January 22, 2014, 10:41:37 PM »
I was tapping up bats today and came across this bat with and area on the face which sounds like its a thin sheet of wood with a gap behind it. It does not go as far as the edges and is only the size of a ball
Is this bat useless or can it be fixed etc. Never seen this before
Delaminated
Overdrive
Re: Is this delamination?
« Reply #1 on: January 22, 2014, 11:02:39 PM »
The problem is easily solved. Just put it on ebay.  ;)
ItsJustCricket
    • Its Just Cricket
« Reply #2 on: January 22, 2014, 11:52:09 PM »
Put a mallet on it or bounce a ball on it first.  Can't tell that much just by tapping it?!
smokem
« Reply #3 on: January 23, 2014, 01:17:36 AM »
More than likely to be delamination - I have a bat just like it and it's getting repaired as I write.
But Paul is right, tap it a bit with a mallet to get a more obvious sound. Don't have to tap it too hard to get an obvious sounds difference.
amritpremi
« Reply #4 on: January 23, 2014, 05:03:19 AM »
I am pretty confident the bat is delaminated, I have 1 such bat  :-[
fasteddie
  • Straight up.
« Reply #5 on: January 23, 2014, 08:39:42 AM »
Sounds very similar to mine.
When I called the bat maker he recommended a repair before it became to bad.
Torque
« Reply #6 on: January 23, 2014, 09:01:26 AM »
Yes, this is delaminated.
