Author Topic: Vibration through the handle of SCAT pro. series 1 cricket bat  (Read 5897 times)
jchokshi
« on: February 10, 2014, 11:38:54 PM »
If I may, I would like to ask a *stupid* question regrading the Screaming cat profession bat series 1 that I just recently received from Julian. I've been trying it out in nets for some time now.
What I've observed is that compared to my old bat (GN Legend 2k13), this new bat appears to be resonating more thus by creating a bit more vibration up through the bat handle that I feel in my hands while playing shots. Both the bats have same grip.
I thought I should ask here if this is because the bat would need a bit more playing-in or I should have 2nd grip or due to lack of any bow in the bat, or something else that I'm doing wrong. Any suggestions?
Thanks,
Jay
PM7
Re: Vibration through the handle of SCAT pro. series 1 cricket bat
« Reply #1 on: February 10, 2014, 11:43:45 PM »
Dont worry about the handle pal, get some pics up. We dont get to see many Scats about :)
jchokshi
« Reply #2 on: February 11, 2014, 12:22:55 AM »
Just received a response from Julian below,
Quote
Bat handles generally break in over a season, they are quite stiff to start with and loosen up and become more flexible over time. I would suggest to keep using it, and the handle should become flexible with use.
Kind Regards
Julian
This is very interesting and a new experience for me as I remembered that I didn't have to go through such process for GN-Legend bat. Anyways, I guess Julian knows better!!  :)
BTW, the same bat can be seen in below video review done by Paul,
Screaming Cat Professional Custom Edition Cricket Bat Review
Thanks,
Jay
Jenko
« Reply #3 on: February 11, 2014, 12:32:06 AM »
Scats have two rubbers in the handle rather than the usual 3 to make them stiffer and get more power through the blade. Also a general rule to see if it's a legit scat :)
alee
« Reply #4 on: February 11, 2014, 04:39:46 AM »
I agree.
My Puma also has two rubbers and with my first time using it even i felt vibration.
Now it's fine i don't feel it anymore.
Wickets-then-runs
« Reply #5 on: February 11, 2014, 08:37:39 AM »
Not sure about the UK Legends but the Aussie versions have a 16 piece handle which reduces vibration right from the start. I've had a few Scats and all of them have stiff handles to start with. I suggest laying another bat on the floor and sitting the end of your Scat handle over it. Stand on the Scat gradually and this will quicken the process up.. Once done, you will love the feeling of the Scat!
Cheers!
« Reply #6 on: February 11, 2014, 10:15:01 AM »
around 4mns 40- that is graping/staining, not a knot!!
Incredible looking bat though
« Reply #7 on: February 11, 2014, 12:56:43 PM »
Cheers!
That sounds a recipe for disaster.
Rob580
« Reply #8 on: February 11, 2014, 01:01:06 PM »
Cheers!
Not sure i'd fancy standing on the handle of a brand new Scat. Rather just play it in a bit longer!
Wickets-then-runs
« Reply #9 on: February 12, 2014, 01:23:36 AM »
I said to stand on it, not jump and down on the bl##dy thing!  ;)
 If you had ever owned a Scat, you would realize just how thick the handles are, especially down towards the blade and they don't "break in" like most other bats...
amritpremi
« Reply #10 on: February 12, 2014, 12:43:31 PM »
Mark, since you owned a few SCs you could afford to take a risk like that, I can never think of doing that to the SC I bought from you.
Wickets-then-runs
« Reply #11 on: February 12, 2014, 08:23:53 PM »
i'm no rocket surgeon, but I reckon the force of a ball weighing 156gms, traveling at 125kmh, that strikes a bat traveling in the opposite direction at 100kmh (I'm not quite sure how fast a bat is swung at) will result in a relatively similar amount of force to someone carefully applying force in the manner I have described.... Any engineers on here?
I'm not advocating bat abuse here: just giving a suggestion to someone that has asked about a stiff handle. I believe Ian Chappell said he did something similar with his bats to speed up the process of getting some "whip" into his handle. Just because I suggest something different, doesn't mean it wrong. If you don't like the idea, I don't have a gun to your head, Amrit!  :D
« Reply #12 on: February 12, 2014, 08:39:13 PM »
Using f=ma, a cricket ball is likely to apply approximately six newtons of force compared to an 80kg human applying approximately 784...
« Reply #13 on: February 13, 2014, 02:34:00 AM »
At our first forum event Matt, a bat maker at Hunts placed then handle of Simmys bat on a solid raised area in the shop and then stood on it to demonstrate the flex. He invited Simmy to do the same, Sim declined!
cesare_in
« Reply #14 on: February 13, 2014, 03:26:55 AM »
:D :D
I must say I am learning quite a bit since I joined this forum.
Standind on the handle must rate amongst one of my top learnings  :)
