Author Topic: Glue For Surface Cracks  (Read 1292 times)
Beaup123
    • Cricket Kit Reviews!
« on: February 15, 2014, 11:36:55 AM »
Hi Guys,
Im doing a Refurb for a mate and there are a few minor cracks on the face and edges, What glue do you recommend to use just to clean them up a bit?
Thanka alot in advance
Re: Glue For Surface Cracks
« Reply #1 on: February 15, 2014, 11:46:20 AM »
PVA.
If the cracks are small and you are unable to open them sufficiently to squirt/spread/inject the glue, then water it down a little bit and then spread it over the cracked area.
Beaup123
« Reply #2 on: February 15, 2014, 11:54:28 AM »
Hi Jake,
Thanks alot for that, So Is an All Purpose PVA hobby craft glue sufficient? (I just found some)
Thanks again
« Reply #3 on: February 15, 2014, 11:58:25 AM »
It should be fine, it may already be watered down if intended for arts and crafts etc.
Beaup123
« Reply #4 on: February 15, 2014, 12:00:27 PM »
Hi Jake,
Yeah It says on the back it has been watered down a little bit, so it should be perfect for the small crack i'm dealing with.
Thanks again
