Author Topic: Latest Refurb Project - GM Epic 505  (Read 2398 times)
wayward_hayward
« on: March 23, 2014, 04:23:23 PM »
I fancied another refiurb project before the summer started and wanted to protect my main match bat during winter nets so picked up a GM Epic 505 off ebay that was only just down the road. The 505 model has an artificial grain sheet and I thought it would be a fun project to see what was lurking underneath.
I decided I wanted to keep the stickers intact so cut round them and peeled off the scuff sheet with ease. Now the difficult bit, removing the grain sheet (made from some kind of plasticy film style material). As a newbee to refurb projects, this bat gave me an opportunity to experience a few methods to bring her to glory. The sheet came away easily with a blunt pair of scissors scaping down the grain but glue used was a (No Swearing Please) to remove. After a few hours spent cleaning her up with the scissors and old credit card, we made some progress!
After a coat of oil (The blade was very dry and think it has been bleached as it was very white) and sanding down the face and edges using sandpaper grades 60, 100, 150, 180, 240 and then 600, the new girl has scrubbed up rather well. And the end result you ask? (grain lovers look away now)
Yes, it really does have only 5 uneven grains and a knot! :D After the initial disappointment of not finding 20+ straight grains, the bat has grown on me in looks, with the knot and random spaced grains giving this bit of willow a bit of character. After all, it is only a net bat! The whole point for acquiring this bat was because it was pretty much the same weight as my other Epic (which weighs around 2.12) but I discovered it weighed a whopping 2.14 when i brought it home. Decided to go through with the project anyway and have managed to lose a couple of ounces (and then put them back on with the weight of my spiral grips) However, it doesn't feel that heavy, with a much lighter pick up than my 2.12 GN Maverick. Size wise, my 707 Epic is probably a touch bigger despite the lighter weight (noticeable at the toe) which proves my point that my 707 Epic is a bit special.
Wayward_Hayward's GM Epic top trumps stands at the following (measurements in mm):
                  707     505
Weight         2.12    2.14
Grains          7         5
Toe highest   30       29
Toe lowest    20       18
Spine           60       55
Edge            34       34
Shoulder       23      22
So was the whole process worth it? While the glue residue was a bitch to remove and took forever (a good couple of hours), it was a good learning process and the thrill of the chase to uncover a beautiful piece of willow (or not in this case!). I can see why the artificial sheets are used to lull people into thinking they have a beautiful bat but I personally think these detract from the individual nature of willow.
I managed to use the new bat in nets this morning and it certainly pings in the middle. In reality, it probably is a touch too heavy for me (2.12 is probably pushing it, let alone 2.14) but it didn't feel much different to my match bat, result!. Also, Shock horror!, this GM is rather soft and requires quite a bit more knocking it before my next net session. Who would of thought it hey?
I will keep this up to date as my net sessions continue and keep a little diary, maybe I will inspire you lot to show us your ugly blades of glory or play Behind the GM Artificial Grain Sheet (potential TV show I think not....).
« Last Edit: March 23, 2014, 04:26:56 PM by wayward_hayward »
Twitter @wayward_hayward
Re: Latest Refurb Project - GM Epic 505
« Reply #1 on: March 23, 2014, 04:56:26 PM »
The 505 is my kind of weight!
Do the grain sheets cost performance? Id have been happy to leave it on.
wayward_hayward
« Reply #2 on: March 23, 2014, 05:09:29 PM »
I can't see it aiding or reducing performance, it was a thin film across the blade. I was interested in finding why GM felt the need to cover it up.
« Reply #3 on: March 23, 2014, 05:16:29 PM »
Probably the knot.
Great to see a clean playing area when revealed.
wayward_hayward
« Reply #4 on: March 23, 2014, 05:27:09 PM »
Agreed, the knot was very prominent and was at a raised level compared to the rest of the blade. Decided to give it a good sanding over and it doesn't look too bad now. I am a bit concerned about its strength and if it will stand up when i edge the ball.
Number 11
« Reply #5 on: March 24, 2014, 02:02:54 AM »
It is what it is, it shows a lot of character having the weird grains and the knot.
I'd much rather have it looking like that than any crap fake grain sheet.
Yes it's an ugly duckling but who's to say it wont see 2500 runs this season.
That knot will take a hell of a bashing being massively denser than the rest of the bat.
« Last Edit: March 24, 2014, 02:04:32 AM by Number 11 »
toenails97
« Reply #6 on: March 24, 2014, 07:29:57 AM »
The edge won't break because it has a knot on it mate, if anything it will keep the edge in tact for longer, however performance around the area may suffer
wayward_hayward
« Reply #7 on: March 24, 2014, 07:37:46 AM »
Performance off the knot is woeful but I don't intend to use the edge much :D
« Reply #8 on: March 24, 2014, 08:22:05 AM »
But if you're going to nick off use the knot and it might not carry!  ;)
wayward_hayward
« Reply #9 on: March 24, 2014, 04:59:44 PM »
Ever the optimist, I like your thinking.
