Author Topic: willow tree  (Read 1203 times)
tommo256
willow tree
« on: March 27, 2014, 04:59:09 PM »
evening,
My boss has a willow tree in his garden and has had some cut off it, would I be able to get some skilled person on here to make me a bat off it please?
L
iand123
Re: willow tree
« Reply #1 on: March 27, 2014, 05:05:21 PM »
Doesn't it need to dry out before it can be shaped?
Re: willow tree
« Reply #2 on: March 27, 2014, 05:20:10 PM »
Would need to be the correct species, grown correctly (ie cared for) and also grown near to a water source.
Even then, simply cutting a 'bit' off may not give you a suitable cleft.
Thats my basic knowledge, i suspect Matt at H4L can help you further.
Re: willow tree
« Reply #3 on: March 27, 2014, 05:23:22 PM »
I'd question which bit was cut off to be able to make a bat? Would need to be the trunk as I doubt you can make a bat from te branches as even the thicker ones would be flexing along during its life and possibly damaged.
Perkins17
    • GM Cricket
Re: willow tree
« Reply #4 on: March 27, 2014, 06:20:06 PM »
Well it depends on which species it is on whether it would work, using as large branch could work but like its already been said that could have a a fair amount of "storm" damage.
Is the tree near a running stream at all as that might affect growth so the grains would not be very good. I would say to get in contact with a willow merchant with some pictures and if its good they could do a deal with you for a finders fee.
Number 11
Re: willow tree
« Reply #5 on: March 29, 2014, 01:02:25 AM »
Wouldn't mind seeing the results of this, c'mon guys, someone give it a go ;)
